View Full Version : Led park/turn wiring questions?
snappytravis
01-24-2015, 05:39 PM
I am doing some wiring on my headlights, park, turn and fog lamps. I have a set of oracle 7inch halo headlights with h4 bulbs. The halos have 2 wires + and -. I want them to come on like drl. Just like new cars, I have 2 fog lamps out of a newer gmc truck. I then ordered a dual color halo that goes inside the fog lamp. It is white and amber and has 3 wires a + and 2 - wires. The lights are triggered off ground wires. One ground is white the other amber.
So here is what I am trying to do,
Key on have halo in headlight that is white come on.
White halo in fog lamp on.
Turn on lights and have h4 bulb on and 2 halos headlight and fog light halo.
Turn on turn signal and would either like to have white light go out and amber flash for turn signal or possible alternate white/amber, white/amber.
The 3 wire deal screws me up a little. I thought it would be ground and 2 hot wires one for turn (amber) and one for drl (white).
I wired a relay into trigger a ground for the white lamp yesterday, Just not sure how to trigger the amber throught a electronic flasher and cancel the white when amber is on.
My only other idea would be to scratch plan A and order a single amber led halo for the fog lamp and just have the single halo in the headlight. Then still run a fog lamp triggered of it's own switch.
Hope all this makes sense,
Thanks for the help guys!
ULTM8Z
01-25-2015, 07:45 AM
Sounds like you're attempting something similar to my setup...
See if this helps...
http://www.lateral-g.net/forums/showthread.php4?t=44534
