    Results 1 to 12 of 12
      Oct 2014
      bowlus minnesota
      4 th gen Camaro brakes on 70 Chevelle
      Hey plan to run 4 th gen Camaro breaks on my 70 Chevelle with a 12 bolt wondering what kind of master cylinder I would need and what kind of proportioning valve I would need kinda on a budget so cheaper the better
      May 2013
      At The Lake
      I used a 7/8 Wilwood Master cylinder on my 4th gen FBody brake set up. I bought the kit that came with the proportioning valve.
      Oct 2014
      bowlus minnesota
      4 th gen Camaro breaks on 70 Chevelle
      Got a picture of the set up and what did it cost. Can you use the stock brake booster?
      If you want to run manual brakes, the least expensive option is a GM 15/16" bore MC. You can get them at your local parts store for about 35 bucks. It comes with a push rod (will need modification, but it's simple). These MCs have a deep pocket in the back of the piston where the push rod snaps in place.
      Raybestos PN MC39946 or equivalent.
      May 2013
      At The Lake
      I did not use a booster. You can Google Wilwood 7/8 Master cylinder for a photo. The kit is about $300.
      Jun 2001
      Newbury Park, CA
      What front caliper are you using?
      Oct 2014
      bowlus minnesota
      I'm using a set of cpp breaks up front and I don't need the booster?
      Quote Originally Posted by chevelle70 View Post
      If you want power brakes, you need a booster. If you want to run manual brakes, you can move the pushrod up to the upper hole on the pedal and use either a 15/16" or a 7/8" bore MC. With manual brakes the pedal is a little firmer but the feedback is excellent.
      Oct 2013
      Maryland
      Right hand drive S10 master
      http://www.amazon.com/ACDelco-18M974...inder+Assembly
      I like the wilwood proportioning valve
      http://www.summitracing.com/parts/wi...1179/overview/
      You will need additional parts
      "Keep Shifting Gears"
      Jun 2001
      Newbury Park, CA
      It may still be difficult to get good F/R balance if a large-bore single piston caliper is used on the front.
      Oct 2013
      Maryland
      Feb 2014
      On my 86 Monte, im using a 15/16 master cylinder from a 79 Riviera.
      I have 98-02 fbody calipers/c5 rotors in the front and 98-02 fbody rears
      86 Monte Carlo SS
      @corybrowning19
