View Full Version : 4 th gen Camaro brakes on 70 Chevelle
chevelle70
01-13-2015, 03:38 PM
Hey plan to run 4 th gen Camaro breaks on my 70 Chevelle with a 12 bolt wondering what kind of master cylinder I would need and what kind of proportioning valve I would need kinda on a budget so cheaper the better
mikewoods
01-14-2015, 05:10 AM
I used a 7/8 Wilwood Master cylinder on my 4th gen FBody brake set up. I bought the kit that came with the proportioning valve.
chevelle70
01-14-2015, 06:31 AM
Got a picture of the set up and what did it cost. Can you use the stock brake booster?
andrewb70
01-14-2015, 07:22 AM
If you want to run manual brakes, the least expensive option is a GM 15/16" bore MC. You can get them at your local parts store for about 35 bucks. It comes with a push rod (will need modification, but it's simple). These MCs have a deep pocket in the back of the piston where the push rod snaps in place.
Raybestos PN MC39946 or equivalent.
mikewoods
01-14-2015, 07:43 AM
I did not use a booster. You can Google Wilwood 7/8 Master cylinder for a photo. The kit is about $300.
CarlC
01-14-2015, 08:42 AM
What front caliper are you using?
chevelle70
01-14-2015, 09:08 AM
I'm using a set of cpp breaks up front and I don't need the booster?
andrewb70
01-14-2015, 10:11 AM
If you want power brakes, you need a booster. If you want to run manual brakes, you can move the pushrod up to the upper hole on the pedal and use either a 15/16" or a 7/8" bore MC. With manual brakes the pedal is a little firmer but the feedback is excellent.
TheParker
01-15-2015, 07:04 PM
Right hand drive S10 master
http://www.amazon.com/ACDelco-18M974-Professional-Durastop-Cylinder/dp/B000C9E5IW/ref=sr_1_1?s=automotive&ie=UTF8&qid=1421377332&sr=1-1&keywords=ACDelco+18M974+Professional+Durastop+Brak e+Master+Cylinder+Assembly
I like the wilwood proportioning valve
http://www.summitracing.com/parts/wil-260-11179/overview/
You will need additional parts
CarlC
01-15-2015, 10:19 PM
It may still be difficult to get good F/R balance if a large-bore single piston caliper is used on the front.
TheParker
01-16-2015, 07:02 AM
This might help
https://www.pro-touring.com/threads/91277-DSE-M-C-amp-Booster-part-s
bad86ss
01-18-2015, 06:04 PM
On my 86 Monte, im using a 15/16 master cylinder from a 79 Riviera.
I have 98-02 fbody calipers/c5 rotors in the front and 98-02 fbody rears
