View Full Version : My 66 Chevelle Malibu build up.
Stained Soul
01-02-2015, 06:48 PM
After messing around with other vehicles I knew it was time to get back to my roots.
I have owned 6 Chevelles and this one is my 4th 66 Malibu 2 door hardtop.
Tail end of Sept. 2014 my father in law and I drove 2300 mile round trip from Spokane Wa. to Fargo N. Dakota to look at this 66 Malibu, 48 hours almost exactly from the time we left, we were pulling back into my driveway.
The owner sent me a pile of pictures so I had a good idea of the condition before we left.
This is a picture of us almost back home....
107919
Next morning she needed a bath in a big kind of way.
107920
Interior pictures:
107921
107922
Engine bay.... control yourselves guys....
107923
107924
Trunk:
107925
Stained Soul
01-02-2015, 07:03 PM
Moving along.
This is what was done to the car suspension wise before I got it.
Detroit Speed, Speed Kit 2 installed, front & rear:
107098
107099
The Previous Owner (P.O.) found a 12 posi out of a 66 Super Sport Chevelle, rebuilt it and put in some 3:73 gears:
107110
P.O. also put CPP front power disc swap
I had a set of Rocket Racing Velocity rims/tires here on another car so I swapped them out the day I cleaner her up from the road trip.
Front 17 x 7 with 225/45/17 & BFG G-Force tires
Rear 17 x 8 with 255/40/17 & BFG G-Force tires
107100
107101
First order of business was to swap out the cpp disc & rotors for some Wilwood 6 piston 12.2" discs:
107107
107102
107103
107104
Stained Soul
01-02-2015, 07:16 PM
Next up, this cpp angle is just not good with my OCD:
107105
This is what will replace the cpp stuff and I will also put some spacers in to level it out a little more:
107106
Before you say, "why didn't/don't you just change out the bracket".... look closely at the first pic... the booster is hard riveted to the bracket.
All aluminum L-33, 5.3
Stock short block, new rings & bearings.
Texas Speed 2.5 heads and lots of other good stuff:
107108
I will be moving the Alternator over to the other side once I have proto-type bracket in hand:
107109
The F-body pan will be replaced with the Holley 302-2 pan.
I have a built 200R4 trans with converter here already.
Radlark
01-02-2015, 07:32 PM
Very nice beginning! Welcome back!
Stained Soul
01-02-2015, 07:34 PM
I have been purchasing most of the needed parts for the engine swap that will start later this month.
These are the BRP Hot Rods frame/engine mounts:
107111
12 bolt aluminum rear diff. cover, Mallory Comp 140 fuel system, & canton over flow for the radiator:
107112
Tom F. turned me onto these guys for my Radiator and I was able place the order for it earlier this week:
http://rndfabrication.com/ABodyearly.html
Here is the cool thing about the above radiator guy: "We can make these for LS Conversion with both ports on the passenger side and with or without the steam port, at no additional charge! "
Goals:
get the engine/trans swap done and enjoy the car as she sits for this coming summer.
I will also be upgrading to power steering.
Upcoming:
HPI frame kit.
107113
107114
While the HPI frame kit is being done we will replace the trunk pan also.
I would really like to do the ABC Performance Mini-tub kit & new inner wheel wells.
http://www.abcperformance.net/mini%20tub%20kit.html
I will have to see how things go with the Autocross I plan on hitting this year as to whether or not I do the ABC full kit.
Thats it for now, thanks for checking in.
L8R,
Stu
Paraman1
01-02-2015, 07:48 PM
Good to see you on here Stu !!
Stained Soul
01-02-2015, 07:53 PM
Thanks Mike, I registered a few years ago... finally decided to be social....... NOT.
I see lots of familiar names/cars on here so thats a good thing.
Have a good weekend everyone.
Stained Soul
01-15-2015, 09:38 PM
Couple of pictures I found in my album.
107653
107654
Radiator should be here by the end of the month... thanks Tom F.
6 banger and glide coming out in the next couple of weeks.
Then strip engine bay, weld up holes, prime, & paint.
And then the fun part, test fit everything........
L8R
Stained Soul
01-24-2015, 08:48 PM
Managed to get a little done today:
Remove:
trans lines to radiator
battery
battery tray
upper/lower radiator hoses
heater core hose
radiator
all wiring connected to engine
fuel line & plugged
master cylinder & short coupling lines
voltage regulator
wiring to alternator
Here is what under the battery tray looked like after removal & hit real quick with a hand wire brush:
108097
Over head pic of engine bay missing a few things… :-)
108098
Not sure I will have the time to pull the driveling & drop the trans tomorrow, something has come up as usual.
L8R
rixtrix1
01-24-2015, 10:21 PM
Nice start on a great project. Subscribed.
1989GTA
01-25-2015, 09:35 AM
Looks like a nice project. Subscribing to the build.
Stained Soul
01-31-2015, 04:24 PM
Yesterday my LS specific radiator from RnD Fabrication showed up.
This thing is BEAST…. :cool:
Thanks Sparky @: http://rndfabrication.com/ABodyearly.html
Thank you to Tom F. for the info also.
108407
108408
108409
108410
Got the hood off of the car today, now comes the fun.
Stained Soul
01-31-2015, 08:02 PM
Hood removed & dropped the drive line today.
Next up: Remove trans. & engine.
108420
Stained Soul
02-02-2015, 08:23 PM
Gutless engine & transmission out today.
Now the fun stuff starts.
108513
108514
108515
Motown 454
02-02-2015, 08:42 PM
Great looking car! That motor and trans is going to be so sweet in there. My wife had a 66 that looked just like yours but it was a 283 and nowhere near as nice. You have a great plan not to lay it up too and enjoy it.
Stained Soul
02-02-2015, 08:49 PM
Thanks Wayne,
I wasn't even sure anyone was really reading my updates.
Seriously thought that the last update just might be the last.
Hopefully she will only be down for a couple of months, no big rush with the crappy weather we are having.
L8R,
Stu
Yelcamino
02-03-2015, 04:20 AM
Progress looks good!
timmy2times
02-03-2015, 05:16 AM
Nice
rchaskin
02-03-2015, 06:26 AM
cool car.....
rrelco
02-03-2015, 08:53 AM
When your ready to spoile that baby look me up....
rixtrix1
02-03-2015, 08:32 PM
Thanks Wayne,
L8R,
Stu
Hey, Stu. Keep those updates coming! I'm subscribed. If I don't have time to work on my '66 Malibu, I can live through yours, and a couple others, lol.
Auto Rod Technologies
02-03-2015, 08:37 PM
Looks like a solid car!!
Stained Soul
02-04-2015, 07:47 AM
Thanks guys.
Hey Rick/rixtrix1, my brother lives in Phoenix and my folks live in Casa Grande.
I'm the sole surviver up here.
Oh ya, and the Pork Shop in Queens Creek has the best damn Pepperoni ever.
L8R,
Stu
Motown 454
02-04-2015, 08:16 PM
I'm watching and enjoying your updates.
Stained Soul
02-08-2015, 12:36 PM
Slow going, but finally getting the engine bay cleaned and stripped down to bare metal.
108663
I finally figured out a decent way to clean up the welds along the frame rails.
108664
108665
More of the same boring stuff for the next week or so.
L8R
dirty ernie
02-08-2015, 02:24 PM
Excellent build!
Stained Soul
02-08-2015, 09:17 PM
Managed to get most of the firewall cleaned up today.
Every time I move the drop light to a different angle I see/find an area I over looked.
Hopefully I can get the rest of the engine bay cleaned up this week.
Still trying to decide if I'm going to pull the grill out and do the front side of the core support.
108694
108695
Bonehead
02-08-2015, 10:39 PM
I hate that part. Looks like you blew through it pretty quick. Looking good!
Arctic_Ragtop
02-09-2015, 09:59 AM
Great choice on the '66, Subscribed. Keep the updates coming. It serves as motivation to get back at it for the rest of us. I really like your attention to detail, and high quality photos. Thanks
Motown 454
02-09-2015, 11:05 AM
When you see how nice the engine bay came out, that will help you make the decision on the radiator support. It looks good.
Stained Soul
02-13-2015, 06:07 PM
Managed to get most of the engine bay done today.
I would guess it's about 90% done, just need to do the edges and a few other small areas.
Also pulled the grill, valance & hood latch assembly off so I can clean the outside of the core support.
I will pull the bumper & brackets off later.
108963
108964
rixtrix1
02-13-2015, 08:02 PM
The Pork Shop is great. Been going there for years. I left NE for warmer weather in 1985. Nice work.
Motown 454
02-14-2015, 10:29 AM
Nice job it looks great. There's a lot of work you've already got done there.
wheatie8252
02-14-2015, 06:57 PM
Looking great, keep.up the good work!
SparkyRnD
02-23-2015, 05:45 AM
108407
108408
108409
108410
Glad you like it, and cool build thread! Looks like it'll be a fun project to play with
Stained Soul
03-06-2015, 08:06 PM
Thanks Sparky.
Todays updated pictures:
109901
109902
Core support all done.
I'm going to get the underside of the front a little bit.
Try not to get to carried away.
Still need to:
Clean cross member underside
Clean front frame rails... underside
Clean corners where wire wheels won't fit.
Test fit engine
Test fit radiator
Pull manual steering box off
Thats the quick list........
