Results 1 to 6 of 6
09-13-2004 #1
Lowering blocks and springs good idea/or bad?
Well I am wondering whether or not to use lowering blocks on my 68. With the leafs being in good shape I would rather use them, but it may lead to buying drop leafs.
Also, what would you recommend using to drop the front? I am using stock spindles and was thinking of hotchkis lowering springs. Can I use stock front shocks? I just bought a set of Monroe sensatrac.
This car is going to be street driven.
Thanks, Andrew
09-14-2004 #2This all depends on what you want to do with the car. For all out performance for the rear I’d look at the cat 5 springs from global west. To get the perfect ride height, go with lowering blocks - moderately -no more than 1".
Front check out guldstrand.com for ideas and spring rates.
09-15-2004 #3global west springs seem pricey. 800 bucks? I am thinking hotchkis 2" drop on rear, and the front drop coil springs. Can I use stock shocks with these coils?
