View Full Version : L99 vs LS3
firebirdzig
12-12-2014, 10:02 PM
Is there a way to tell the difference between an LS3 and L99 other than seeing a manual or auto trans attached to it? Is there maybe a different number stamped on the block? Any help is greatly appreciated. Thanks!
71maroesteban
12-12-2014, 11:40 PM
A l99 will have a water pump that is sort of spaced out as it has VVT and DoD which can been seen once you remove the intake the valley cover will have like a maze Pattern other than those two things the blocks and heads are the same
firebirdzig
12-13-2014, 04:06 PM
What do you mean by spaced out?
130fe
12-13-2014, 07:48 PM
Don't the L99s also have VVT? LS3s do not.
1989GTA
12-13-2014, 09:13 PM
That is correct. The easiest way to tell if you know what you are looking for is the camshaft timing chain cover.
firebirdzig
12-13-2014, 09:48 PM
Is there a picture comparing the 2?
dhutton
12-14-2014, 06:14 PM
Here you go:
http://www.speartech.com/category_s/1822.htm
Don
firebirdzig
12-14-2014, 08:12 PM
Thank you very much
