    Results 1 to 12 of 12
      Sep 2012
      San Diego
      caliper kick back or drum brakes?
      im new to autocrossing and have a new to me car that ive started autocrossing with. its a 71 maverick with 4 wheel wilwood disk brakes. as i digest my experience on the autocross i realize i was experiencing caliper kick back with the pedal needing more travel than normal. so i had a similar car with wilwoods on the front and 11x2.5" drums in the rear. it stopped really well but i never autocrossed with that car. mostly it was a street strip car. my question is, would it be worth swapping to the drum brakes to not have the kick back problem?
      71 maverick.
      71 comet in build process.
      i work at Current Auto Performance www.currentautoperformance.com. i also build the differentials for San Diego Gear and Axle.
      Jun 2014
      East coast.
      what kind of rear calipers are you using?
      Sep 2012
      San Diego
      71 maverick.
      Dec 2011
      How old are your wheel bearings? The more play and deflection they allow, the more knock back you're going to get.
      I'd change those first and see if it decreases your knock back issue. It's important to note that you're always going to have a bit of knock back in a disc brake system.
      Sep 2012
      San Diego
      they are 3 years old. about 10,000 miles on them. ill check them. still no input on the possibility that rear drum brakes could provide better consistency that the disk brakes with the knock back?
      71 maverick.
      Jun 2012
      With 9" style bearings you should not have knock back. If you have c clips then go with a floating caliper.
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Jun 2014
      East coast.
      Under racing conditions the 9" press in bearings do knock back pads. I see this all the time with my American iron racers.
      you'll need to switch to a floating caliper, or a floating axle.
      Please don't go back to drums, nobody likes drums :P
      Dec 2010
      Fredericksburg, VA.
      Going to drums is a step backwards. Floating calipers or floating rotors is your best course of action.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Apr 2012
      Woodstock, IL
      Yep what all they said.
      Drum brakes are the best, but only once. Then they're too hot and fade quickly.
      We use floater rear ends on all of our chassis to prevent the knock back.
      The only way to get around it with a regular 9 inch using a fixed caliper is weld the bearing retainer onto the axle shaft
      -Dale
      SchwartzPerformance
      Mar 2010
      Okinawa, Japan
      Yep what the last 4 or so folks said, either floating axle or calipers is the only way to remove knock-back. Didn't Wilwood develop a retrofit bracket and caliper for those that wanted to upgrade to a floating caliper from their fixed caliper rear kit? I know they sell a floating rear caller kit now but wasn't there some people on hear that talked Wilwood into making the kit and were able to just get the bracket and caliper?
      Feb 2011
      Indpls, IN
      Apr 2012
      Woodstock, IL
      That's a floating caliper kit yes. Any caliper that mounts with a pin like that is a floating caliper.
      -Dale
      SchwartzPerformance
