    Results 1 to 1 of 1
      Jun 2010
      Philipsburg, Pa
      UMI Releases New Product- Adjustable Upper Front A-Arms for the 78-88 GM G-Body
      Adjustable Upper Front A-arm for the 1978-1988 GM G-Body
      P/N 3056, 3056-1, 3056-2, 3056-3
      Price Starting at $449.99
      Today’s Pro Touring G-bodies are handling like never before. Achieve your goal of awesome handling with UMI’s new 3056 adjustable upper a-arm. This arm precisely locates a tall upper ball joint which in turn improves the camber curve and results in more front end grip. The advanced design of the a-arm also relocates the ball joint plate rearward for increased caster and improved stability and steering feel. The CrMo cross shaft holds two precision rod ends which are used to adjust the caster and camber. These precision bent tubes are TIG welded to the laser cut ball joint pad which houses a 1.0” or 0.5” taller upper ball joint (standard or deleted ball joint also available). A laser cut bump stop brace completes the arm. If used for drag racing, the 3056 can also accommodate a travel limiter. In addition, the 3056 can be used with most other aftermarket tall spindles intended to fit the G-body application. The 3056 is available in beautiful red or black powder coat. UMI chooses US materials and proudly designs, manufactures, races and tests out of our facility in Philipsburg, PA – USA.
      WEB SITE LINK HERE
      P/N 3056-3 shown with 1" taller upper ball joint
      P/N 3056-2 shown with 1/2" taller upper ball joint
      Ryan
      UMI Performance
      www.umiperformance.com
      814.343.6315
      Join us on Facebook!
