    Results 1 to 4 of 4
      Chit-ca-go
      How are you guys mating Wilwood Emergency cable to GM cable
      Would've been great if the threads to the block from Wilwood were the same as the OEM GM foot operated cable. How are you guys mating the two?
      1971 Firebird
      2017 Slipstream SS
      Oct 2013
      I just drilled out the block, slid the rod through and used a nut on each end. worked well.
      Chit-ca-go
      Thanks. That's was my original thought too.
      1971 Firebird
      2017 Slipstream SS
      May 2010
      Mooresville, NC
      Quote Originally Posted by dragonfly jones View Post
      Same here, works perfectly! I used a double nut (jam nut) after the block.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
