    Results 1 to 6 of 6
      Eastern Virginia
      Looking for Dimensions of 80's G body rear axle flanges.
      I am working on some rear disc brake brackets for 80's G body cars. And would like to verify my dimenstions of the axle flanges. Does anyone have, or know where I can find these dimensions. For thos who don't know, the G body rear was GM's step child. It does not have the normal 4 bolt flange. It has one big hole where the wheel cylinder when through & two small ones on the underside of the axle that had (I think) a 10mm bolt in each one.
      Scot
      Scot
      86 Monte SS
      May 2002
      Northern California
      Hi Scot,
      Try the Moser site, there is a link to a flange I.D. page. You can also remove your brake backing plate and make one up from that.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Eastern Virginia
      I checked there. They don't show it.
      Scot
      Scot
      86 Monte SS
      May 2002
      Northern California
      You might want to call and see what year this is for. I thought early BOP was the same as Chevy.
      http://www.moserengineering.com/cata...artemplate.asp
      Well after digging a bit I found this...
      looks similar to a 3rd gen drum brakes rear flange...then you can do a swap similar to this....
      Eastern Virginia
      I don't want to do any cutting/drilling on the axle flanges. I have all the locations except for the two small holes at the bottom. Those are what I need locations for. It doesn't seem like they are centered on the line between the axle center & top holes.
      I saw Moser's website & they don't have this flange shown.
      yes it is just like the picture you had shown. I thought it was only on the G body cars.
      Scot
      Scot
      86 Monte SS
      May 2002
      Northern California
      Yeah kinda sucks that they welded the flange on. If you have your backing plate you can have some one make an adapter bracket for you.
