View Full Version : Wilwood Narrow Superlites on an A-body
kevmurray
10-26-2014, 06:33 PM
I'm shopping for a new brake system and I'm leaning toward the Narrow Superlite kit.
http://www.summitracing.com/parts/wil-140-12271
http://www.summitracing.com/parts/wil-140-9213
Anyone install these on an A-body and did you have any issues? Park brake connect up easy and work well?
Also, I'm running a 12 bolt rear and knock back is one of my concerns. Is there a fix that does not involve going to a full floating axle or c-clip eliminators?
andrewb70
10-27-2014, 03:56 AM
I can't comment on those kits because I haven't used them, but for the rear you really should run a floating caliper to avoid pad knock back.
kevmurray
10-28-2014, 04:54 PM
How does anyone get away with Z06 rear brakes on a live axle? They are popular but don't have a floating rear caliper.
Can anyone recommend a nice brake system that has a rear floater? It seems all the serious ones are fixed. :confused:
Hugger67RSSS
10-28-2014, 06:36 PM
Trust me you don't want C6 Z06 brakes without a floater, changing mine out this winter and found the thread I bumped back up to the top titled Camaro performers rear brake kit
andrewb70
10-28-2014, 07:13 PM
I run the LS1 4th gen fbody rear calipers with my C6Z06 fronts. They balance out nicely.
kevmurray
10-29-2014, 02:49 PM
Thanks for the info Andrew. You've been very helpful as always.
Aarik thanks for the bump, I'll read it tonight.
