    Results 1 to 19 of 19
      Jul 2009
      Cypress, TX
      Trouble with Wilwood master cylinder
      Finally gave up trying to bleed my rear brakes and took it to the shop. I've got a Wilwood master, wilwood calipers on all 4 corners , a booster and an adjustable valve in the rear line. The shop tells me that the rear brakes portion of the master cylinder isnt supplying pressurized fluid. They recommending getting a new master. Not much to go on, but has anybody else had problems with their Wilwood master?
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Jul 2009
      Cypress, TX
      I'm considering putting OEM master on at least temporarily. Anything I need to do to the OEM master to accommodate disk brakes on the rear?
      Mar 2013
      Beaufort,SC
      The cylinder swap should be find the proportioning valve adjusts pressure. did you bench bleed the M/C?
      Jul 2009
      Cypress, TX
      Yes, I bench bled.
      Quote Originally Posted by no go nova View Post
      Mar 2013
      I see sooooo many brake issues on not only this forum but others as well. One issue that so many times is overlooked is the "volume" issue. When brakes are upgraded this must be considered. In short, the master cylinder when depressed all the way (many have a 1.00" stroke) displaces X amount of fluid. This amount must be more than the volume of the area in each caliper after the pistons are moved completely out and applying pressure to the pads. IF it is not, you will have poor or no brakes. Most of the time you will find, your master cylinder is just too small.
      Jul 2013
      St Louis
      Quote Originally Posted by terrydmorgan View Post
      Im having the exact same problem, Ive even swapped out Wilwood MC. I just assumed it was air, I mean how could 2 Wilwood MC be bad, right lol? BUt I have yet to be able to bleed the rear.
      Pontiac Powered 72 GTO
      Jul 2009
      Cypress, TX
      I don't think volume is my issue. I'm just not getting any pressure out of the rear port. Unfortunately, Wilwood's tandem aluminum master cylinder doesn't have a rebuild kit. You have to send it in for repair.
      Quote Originally Posted by IMPALA MAN View Post
      Jul 2009
      Cypress, TX
      I'm about to try a second master cylinder too. I'll let you know if that clears up my proble. What are the odds that there are 4 bad master cylinders?
      Quote Originally Posted by Gratefuldiver View Post
      Oregon
      How did you bench bleed the master cylinder? Recirculation or plugged port method? If you used the recirc-method with the tubes and fittings supplied with the master cylinder, I would still suggest that you confirm the MC is fully bleed by plugging both outlet ports and verifying that the piston hydraulically locks after about 1/8" of stroke. If it doesn't, then you either have air in one or both chambers or you have a bad seal. If it's air, slowly stroke the piston and watch for air bubbles returning into the reservoir...if it improves, then you know that was most likely the issue. if you stroke the piston repeatedly without any sign of air, then it's probably fluid bypassing a seal internally.
      Even if you don't have a rebuild kit, you can still pull the piston assemblies out and make sure there isn't a chip or something causing the issue.
      Tobin
      KORE3
      It's what I does.
      Jul 2009
      Cypress, TX
      Thanks for the tips Tobin. I bench bled using the re circulation method. I'll Block em off and see what happens.
      Quote Originally Posted by Apogee View Post
      Tobin
      KORE3
      Jul 2013
      St Louis
      Not trying to hijack but what I think I found today was the rod in the booster was extended to far and it wasn't letting the MC come all the way back down. I also capped all 4 ports on the MC and bench bleed till I had no bubbles and I could hardly even push it in anymore as Tobin said. Have to go to the kids game now so Ill post results final results later. I can say for sure the MC is good
      Sep 2014
      First rule of MC install mechanics. The pushrod must not hold the MC piston from returning completely.
      If the piston does not return completely the relief/fill port will not be uncovered.
      Most boosters have an adjustable tip on the pushrod.
      Jul 2009
      Cypress, TX
      Well, how about that. I bench bled using the plugged port method, and air bubbles were ejected into the reservoirs during each stroke for about 10-15 strokes. After that, the air bubbles stopped and the piston hydraulically locked after about 1/8" stroke. I guess my master cylinder is good and my mechanic is mistaken. I'll reinstall the master and try and bleed the whole system. Never heard of the plugged port method of bleeding before this, but it looks like a real winner. Thanks Tobin!
      Jul 2009
      Cypress, TX
      Brakes are working! Turns out we needed to adjust the plunger in the booster. Car stops well with no squeeling, shaking or shuddering. Thanks for all the help guys!
      Jul 2013
      St Louis
      Good deal, looks we both had the same issues.
      Nov 2014
      Byron, Ga
      terry, what size wilwood master cylinder are you using?
      '66 Chevelle BBC/TKO600r, Holley Sniper EFI, Tanks Inc, RideTech Air Ride, Wilwood, Billet Specialties Toploaders 19"/20", Nitto NT555G2, Octane Lighting LED, DIGI-TAILS Front & Rear, Randy's Spoiler
      Jul 2009
      Cypress, TX
      My records show that it is a 1" Wilwood dual master cylinder, but I wouldn't swear that to be true. Is there any way to tell without tearing it apart? Part number?
      Jul 2013
      St Louis
      There is a 1" stamped on the MC
      Jul 2009
      Cypress, TX
      Yep, it's a 1" master cylinder.
