    Results 1 to 5 of 5
      Aug 2013
      Anyone with wayne due subframe
      I'm try to find out what sway bar I'm supposed to use on wayne dues subframe it's for a 69 camaro also he supposed to use nova front bumper brackets I was told not camaro I don't have any paper work that shows this info only the chassis and inner fender info nothing on the sway bar or bumper brackets any help would be appreciated thanks
      Pensacola, FL
      I have a wayne due in my 69 camaro. Its the older C4 design. I searched extensively for what sway bar would work on it, but everything I found was that wayne made the bars for the frames, and any aftermarket would require some mods to make one fit. So I just left the sway bar on that came on it. If I remember correctly, speedway motors is where a few guys got a sway bar that they made work. I can take some measurements for you to get you in the ballpark. I used all factory 69 camaro bumper brackets with no problem.
      Scott
      Aug 2013
      Thanks yeah I called speedway engineering twice left a message and the tech guy never called me back mine never came with one so I have no idea what it should have but thanks for the brackets that helps a lot
      Any leads on how to get a way bar for that same set up ???
      Des Moines, IA
