    Results 1 to 5 of 5
    Thread: bad shocks
      Jan 2013
      bad shocks
      Can bad shocks are give you a vibration at the brake pedal i thought it was my front tires but i had them look at and road balance and they said they was find i get the vibration at 60 mph i had the car drop about 2" all the way around with QA coil over shocks new tubular upper and lower control arms and i went with SSBC brakes front and rear disc new sway bar.
      Apr 2007
      No. But, if you have a vibration, weak shocks can fail to dampen it.
      I would *not* call QA1 coil overs weak shocks (unless you bought them trashed on Ebay).
      Set the shocks full hard and see if it makes a difference.
      Could be driveshaft related?
      Feb 2011
      So CA
      Have a look at tire balance and rotor flatness. Does the vibration occur all the time or only when your foot is on the brake pedal? If it's when you are on the brakes one or both of your rotors need cleaning up. If not tire balance.
      Sep 2010
      Benicia, Ca.
      Make sure the rear rotor mounting surface (axle face) and the back of the rotor was clean and true, I have seen quite a few out of true rear axles show up with a rear disc swap.
      If I can be of more help let me know.
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
      Dec 2008
      Detroit
      Have you started with the basics, putting the front of the car on jack stands and tugging on the wheels? You want to verify all your suspension components are tight.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
