    Results 1 to 3 of 3
      Feb 2007
      200 r4 will not lock up in fourth gear ( B&M controller )
      I just put in a 350 with a 200 4r trans in my 72 nova. I also hooked up a B&M lock up control with a NC brake/cruise switch. I took it for a test drive to check the pressures and they all look good but when it goes into 4th gear it will not go into lock up, even if I try it manually with the controller. I have also replaced the TCC solenoid when I serviced the trans before I installed it. I tested the old one and it would not click tested the new one it was good.
      Does anyone have any checks that I could do to find out what is wrong?
      any way to check the converter? I hope that's not the issue
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      How many miles are on the trans and was it dry before install? The reason I ask is the 2004R takes a bit to get fluid through all the circuits. Drive a few miles, check fluid, repeat.
      Feb 2007
      It had clean fluid in it before install. I have driven it about 7 miles and checked the fluid. Clean full at idle and trans at running temp
      Brandon Slater
      1979 Z28
      1972 Nova
