View Full Version : LS3 416 cam specs????
Tom5410
09-23-2014, 09:59 AM
Folks,
Need opinions, thoughts on Cam specs.. Going into LS3 416, being built from ground up.. Looking at Comp Cams #54-474-11. 251 intake/267 Exhaust 115 Lobe
Mainly street car.. Will do some track days/autocross. Want driveablitly on the street.
71RS/SS396
09-24-2014, 09:34 AM
I would go a little more conservative if drivability and street is the primary use. I had this one in my LS7, pulled well off idle and mid-range http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1411&sb=0
carguykeith
09-25-2014, 01:36 AM
If you're building a 416 LS3 from the ground up I'd have a custom cam spec'd. It's what $50 more than an off the shelf grind in a $8-10K build and you can get exactly what you want for your specific combo.
Just my $0.02
