    Results 1 to 4 of 4
      Sep 2013
      Rosamond CA
      need some help figuring this triangled upper bar in a tight frame
      Hello, need some help with my upper tri-angled bars, currently there sitting at 45* off a cross bar. I've been told that i should be more at 50-60* but wasn't 100% sure. If i don't plan on running a watts link or panhard bar would i be fine with 45*. What your take or recommendations.
      I included a few photos where i am at currently.
      Thanks for the help
      Ron
      Sep 2013
      Rosamond CA
      If I do keep these upper bars at the 45* angle, making a upper mounting point may be a little difficult with the inner U bolt in the way. Any suggestions on mounting the upper to the tubes?
      Feb 2011
      Indpls, IN
      I would get rid of the bolt on mounts and go to a weld on mount. that would get rid of the u-bolts.
      Dec 2010
      Fredericksburg, VA.
      I agree you are going to have to eleminate the u-bolts and weld on mounts. The alternative is to reverse the angle of the bars. Inboard on the axle to outboard on the frame like this.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
