    Results 1 to 4 of 4
      Jun 2006
      Katy,TX
      What flavor of front wheel bearing grease?
      So what is the most common one you guys are using? I have used mobil 1 for years but the last one I used it on I had moderate separation(liquid from the solid) actually leaking past the leather Wilwood seals(had a post here a couple of years ago about it swapping to a rubber seal that fit resolved it-although if Wilwood machined the hole just a hair bigger the double lipped factory seal would work).
      Putting a new setup on the 81 TA and about to break out the grease!
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      Aug 2014
      I use Redline CV-2
      Lawrenceburg, TN
      Southern Indiana
      moly based grease OR synthetic like Mobil 1 or other brand.
      Lee Abel
      AFTERMARKET PERFORMANCE
