View Full Version : installing passenger side control arms
69firebird19
08-09-2014, 05:39 PM
Any else had trouble installing the passenger side lower control arm its from global west and for a 1st gen f body..doesnt want to go inside the slots to bolt them up driver side was easy to do
andrewb70
08-09-2014, 05:55 PM
It often happens that the tabs that hold the control arms get smushed when the control arms are tightened, especially with rubber bushings. Take a soft mallet and open up the openings a little.
68zz502fi
08-09-2014, 06:12 PM
Or, you could make one of these simple tools and spread the opening(s) until the control arm fits...
101069
Rod
08-09-2014, 06:19 PM
its forty year old steel, it has to be persuaded, pry bars, rubber mallets...remember its says bolt in, its not.....you have to help it along
69firebird19
08-10-2014, 10:45 AM
Thanks will do...how u make that tool
68zz502fi
08-10-2014, 03:18 PM
I haven't made one yet... I think Camaro control arm bolts are 5/8". Get a 5/8" stud or bolt and cut it down to about 1" or so longer than the gap in the frame. Get 2 nuts and 2 washers (5/8) as well. I'd use grade 8 hardware for this tool, and make sure you lightly oil the stud/bolt.
Buryingthesun
08-11-2014, 02:38 AM
I would use a piece of threaded rod and two nuts to spread it. . . No im just kidding id probably smack it a couple few times with a mallet.
Rick Dorion
08-11-2014, 03:39 AM
That's what I did. Easy job! Good luck!
69firebird19
08-11-2014, 09:39 AM
Hope its easy i havent tried to smack it since i havent had time to work on the car
68zz502fi
08-11-2014, 01:26 PM
I'd probably use the stud and nut spreader tool. You could use a big rock if you like... To each their own.
