View Full Version : Help, superlite 11 rear brakes with e brake
Biltx77
08-07-2014, 05:48 PM
So I have a set of Wilwood superlite II calipers (rears) and 4 rotors (two piece 8 hole 7 in spread) I think they are 11x1.25in , I would like to put together a rear parking brake setup and use these on a ford 9in new style big bearing rear.
I need
Hats
Brackets
Parking brake assy ( i would like to use the drum in hat setup, they seem to actually work )
If anyone has done this I would appreciate any help
MCB Matt
08-28-2014, 02:20 PM
Honestly, in this situation, since Wilwood discounts their "kits" if you buy each piece you will end up spending the same if not more than just buying a correct, new, full kit.
If your calipers are not sealed and have been open a while, the seals may be dried out too.... It can turn into a mess quick.
Let me know if i can help.
Matt
