    Results 1 to 12 of 12
      Dunwoody, GA
      Gbody Elky guys. widest rear wheel?
      thanks to Tony's fitment guide I can see that at least a 9.5 wide rim can be fit in the rear of a Gbody Elky. is this the widest rim that will fit? i didnt take any measurements only looked, but it appeared that the wheel well is fairly square and with the inner lip rolled could fit a 10in wide rim with no frame or body modifications. what about if the car is lowered? like i said i just looked and the tires were on the car too, but the wheelwell looked square enough that if the rim would fit between the frame and inner wheel lip everything would be ok. any one know for sure? thanks for the info.
      Trey
      ~ Jon Hammond
      hi,
      on my 1979 El-Camino i have on the rear axle 10x17" with 255/40ZR17. you can also drive with 265/40.
      Backspace is 4,5"
      greets
      Klaus
      Dunwoody, GA
      awsome, did you roll the inner lip to get that to fit?
      Trey
      ~ Jon Hammond
      Nov 2002
      Georgetown,TX
      Jack the back end high enough and just about anything will fit.
      Dunwoody, GA
      hahahaha wrong way man. im going lower if i do anything
      i would ride at least as low as Klaus' or maybe even lower or bagged even. so this could get interesting if I try to push it with the width.
      Trey
      ~ Jon Hammond
      yes, i roll the inner fender lip a little bit.
      i drive with the Hotchkis coil springs, front and rear aprox. 2" lower
      greets
      Klaus
      Dunwoody, GA
      thanks Klaus youve been a big help. I appreciate it.
      Trey
      ~ Jon Hammond
      hi WS6
      no problem, i´m happy when i can help here in Europe a Elky-man in USA
      greets
      Klaus
      Rolla, MO.
      18x10 with 5" backspace and 275/35's on my Malibu
      Matt
      1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
      RatMalibu
      looks fine.
      i think 5" backspace is the maximum. one times i testest wheels with a 5,5" backspace on my Camino, but the wheel scrubs on the frame.
      greets
      Klaus
      Dunwoody, GA
      awsome. thanks guys.
      Trey
      ~ Jon Hammond
      Oct 2010
      17x10 Boyd Coddingtons
      I dont have pics yet but I will, however I am running on the rear of my 1978 Malibu a 17x10 Boyd Coddington turbine with a 315-35-17. The car from the rear looks crazy with that much tire...
