    Results 1 to 3 of 3
      Apr 2011
      What am I not looking at? Baer on front, Wilwood on rear
      I have a set of Baer 6 pistons that I was going to put on the front and also have a nice set of Wilwoods 4 pistons that I could put on the rear. Is there a reason that you would not want to do this?
      Thanks for your opinions.
      Apr 2012
      Woodstock, IL
      Not really.. If you want to get technical, the piston area of each can make a difference , but if it's a 6P an a standard 4 piston Wilwood then you're probably fine.
      It'll just look funny, that's all.
      -Dale
      SchwartzPerformance
      Dec 2010
      That is exactly what I have on my car with mechanical bias adjust on two master cylinders. Rear rotor is 12.2 front rotor is 13. I do use the came Carbotech AX6 pad on both calipers and the system works great.
