View Full Version : Alignment turntables, where to get a pair?
pitts64
07-27-2014, 06:18 PM
Who has a good deal on alignment turntables?
Thank you,
Jeff....
Schwartz Performance
07-27-2014, 07:01 PM
Only ones i've ever seen are all pretty expensive.. I've seen some DIY turntables in the past, google that.
http://www.summitracing.com/parts/sps-99750/overview/
Ron Sutton
07-28-2014, 07:28 AM
Thank you,
Jeff....
Hi Jeff,
I carry 3 brands around $700 a set. You can see them HERE (http://shop.ronsuttonracetechnology.com/shopping/?ic=9342). I prefer & use the Joe's Racing, as their stuff is always super nice & well made.
Best wishes.
MonzaRacer
07-31-2014, 12:03 PM
a quick note you could also use 2, 12 in square 1/4" thick pieces of lexan, get a counter sunk allen head bolt around 3/8 or 7/16 drill and helicoil bottom piece use white lithium grease between and only tighten up screw enough to hold them together, trim bottom of bolt flush and tada. Ill see iff I can find the actual set of plans i have.
also look around on Ebay, wheeltronics, John Bean, Hunter, and several others all use same balls for replacement and looking up Stempf part number and googling can get you new balls easy enough as long as rings and springs inside are good.
eric1967
07-31-2014, 01:05 PM
Check some of the older auto or tire shops. I bought a set from a local tire shop that had been there for years.
regal454
07-31-2014, 01:21 PM
I made my own using 2 pieces of 12x12 aluminum with wheel bearing grease between them...works perfectly!
dhutton
07-31-2014, 03:31 PM
I got a set for a good price on eBay. Not the best but I don't use them a lot.
Don
Rick Dorion
08-01-2014, 04:10 AM
Ebay for me too. I've done about 6 alignments on a few projects and this fits my needs. It was a couple of years ago but I believe I paid about $100 plus shipping. Again, they're cheap but suitable for my home hobby need.
Buryingthesun
08-01-2014, 04:54 AM
I built a set, 12"x12" 1/4" steel plates and trailer hubs with bearings. . . its hood as f*ck lol
