    Results 1 to 1 of 1
      Jun 2006
      Katy,TX
      Second gen F body spring wheel rate vs at spindle
      The front end is going back on the 81 TA and with weight under the LCA at the ball joint ride height is correct-how much will I loose with weight out on the wheel(increasing lever arm lenght)? 700#/in springs.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
