    Results 1 to 9 of 9
      Feb 2006
      Tennessee
      How to make clean 4 hole cut for Vintage Air hoses?
      I may have done a poor job of searching, but how does everything cut the 4 holes for the hoses to pass through on the Vintage Air install? Are the holes a standard size for the hoses and grommet?
      My car's firewall is smoothed, but I want to get the holes in before it goes in for paint. I've read about bulkhead leaks so I'm not considering that option.
      Kerry
      66 Chevelle - LS-Leap
      LQ9 / T56 Complete - Phase 2 in process!!
      https://www.pro-touring.com/threads/...t-LS-Heap-quot
      SC&C, Kore3, Detroit Speed, BBS, Advanced Induction, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock LS-Kit, Mast, Wilwood, BP-Automotive, StopTech, Ridetech, Hotchkis, UMI, Energy Suspension, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
      Mar 2004
      Mid-Michigan
      As far as I am concerned the ONLY way to do this is with a Blair Rota-Broach. Hit eBay for them, best prices you'll find. These cut a very clean hole with little effort.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Sep 2010
      Beach Park IL
      1 1/4" if using the vintage air grommets for all four hoses. RotaBroach is awesome, but I prefer to punch them if I can get at both sides.
      Donny
      Feb 2006
      Tennessee
      Thanks guys!
      I searched ebay, and there are alot of RotaBroach bits. Do they take a specific tool to use or just a hand drill will work?
      Mar 2004
      Mid-Michigan
      Hand drill will work very well. Drill a guide hole that is tight to the pilot of the broach. This will keep the broach from wandering.
      This is a hole I made for a battery cable pass-thru.
      What little burrs are left by the broach I clean up by lightly hitting the hole with a step drill. This hole was sized for a snap bushing and it fit perfectly when done.
      The snap bushing and cable installed.
      Mark:
      Feb 2006
      Tennessee
      Well, I found what I need easily. That said, the 1.25 bit requires a drill with a 1/2 chuck. I'm going to order the bit while asking all my friends if they have the right drill for it...lol
      Edit: Found the 4 hole template with further google searches.
      Thanks again,
      Kerry
      Mar 2004
      Mid-Michigan
      You may as well pick up a drill also. You'll have the broaches and you will be wanting to use them. Even if you just go to Harbor Freight and pick up a cheap 1/2" drill it will do what you need it for.
      http://www.harborfreight.com/power-t...uck-68850.html
      Mark:
      Feb 2006
      Tennessee
      Quote Originally Posted by astroracer View Post
      I was actually looking at that exact drill yesterday. I like my Dewalt for around the house duties, but this might give me a garage only version.
      BTW, I may be overthinking this while waiting on the Rotabroach to deliver, but do I need to support the firewall while drilling the holes? I doubt the first or second hole will be a problem, but when I do the 3rd and 4th will the metal be weakened from the missing metal?
      Kerry
      Mar 2004
      Mid-Michigan
      No, shouldn't be an issue. You don't have to push that hard with these hole cutters for them to do their job. Make a couple of practice cuts on scrap just to get a feel for them. You will be surprised at how well they work.
      That hole I pictured in the above post was on a piece of 20ga that was attached to the fenderwell on one side only. I would not have attempted drilling that hole with a step drill. I just used light pressure and it cut like butter.
      Mark
      Mark:
