Gratefuldiver
07-02-2014, 10:56 AM
Seems I have a little mismatch going on in my braking system. I have Baer track 4's up front with Cadillac single piston calipers on the rear. The single 2 13/32 piston in the rear actually has more volume then the fronts lol so Im looking to correct that.
Baer said to get something that had about 1/2 the volume of the front (Track 4 are about 4 in. squared) and the Wilwood dual piston D154 with 1.12 piston is 1.98 in squared. I also want to change my MC to a Wilwood 1" bore to replace the SSBC 1.125" bore MC I have now, but for now replacing the rear calipers is my #1 concern and don't want to do this again. If I had the cash Id buy the matching Baer system for the back but that's not happening any time soon. That and the D154 are direct replacement minus the e brake so I can do it on the cheap.
Anybody running the Track 4 and D154 combo and if so do you like it?
Other info, running 11" rotors in back and a 9" booster with a vac pump. Not sure if the booster will be needed once I install the 1" bore MC but I guess it cant hurt.
