    Results 1 to 6 of 6
      Oct 2007
      Shawnee, KS
      1/4" line down to 3/16" from MC to Prop Vlv
      I have my late model booster and MC from mounted on my 67 camaro. I also bought SSBC's prop valve (shown below). I need to build a line or use an adapter for the front 1/4" MC line (rear brakes) to reduce to the 3/16 line for prop vlv. Is there an adapter that will thread into the MC (M12x1) that I can thread a M10 or 3/16 bubble or inverted flare into (something similar to the brass fitting in the Prop vlv pic)?
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
      Oct 2007
      Shawnee, KS
      I found on another site that the 1/4" line fitting (farthest from the booster) for the rear brakes is a M12x1 where the closest fitting to the booster is a M10x1.5 fitting. Still looking for the adapter.
      Shannon
      Oct 2007
      Shawnee, KS
      OK. I think I found it.
      Doorman PN 499-006
      Type: Bubble Flare Adapter
      Female Thread Size: 3/8"-24
      Male Tube Size/Type: 3/16"
      Male Thread Size: M12-1.0
      Thread Size End 1: 3/8-24 Inch
      Thread Size End 2: M12X1.0
      Line Size End 1 (In): N/A
      Line Size End 2 (In): 3/16 Inch
      Shannon
      Here are some additional numbers:
      Code:
      Edelmann #   Everco #    Weatherhead #    Female Inverted Flare Seat    Male Bubble Flare
      265000        3014        7974        3/16" (3/8-24 thread)        12-1.0MM
      Bob.
      Oct 2007
      Shawnee, KS
      Thanks Bob for the info.
      I had already ordered the Dorman pn and it came as a box of 5. So I have extra.... Should have waited. Oh well....lol
      Shannon
      Southern Indiana
      WOW I have found all sorts of tube nuts at Pep Boys and I also have a source on brake line and fitting kits. Come with like 25 ft of the cunifer corrosion resistant line in 3/16 or 1/4 and many of the specialty tube nuts, like the Ford left side 3/16 x 7/16 truck rear axle nut. I can get a 3/16 kit or 1/4 kit. They come with plastic box full of metric and standard tube nuts and fittings and adapters. For like $150 plus shipping the 3/16 makes doing lines soooooooo easy. 1/4 kit is even cheaper.
      Lee Abel
      AFTERMARKET PERFORMANCE
