    Results 1 to 9 of 9
      Jul 2009
      Cypress, TX
      Ford 9" rear end bracket for brake line
      I need some help running my brake lines in my '69 Camaro. In the '69 Camaro rear brakes, a single hard line couples to a flex line that has a distribution block feeding two lines, one for each rear wheel. The distribution block bolts to an L-shaped bracket connected to a cover bolt on the rear side of the 10-bolt rear end. I have a Ford 9" rear end and the bracket for the distribution block doesn't fit well. Anyone have a suggestion on how to mount the rear brake line, particularly with respect to the distribution block.
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Apr 2012
      Woodstock, IL
      Can you weld something like a nut or bung to the rear end housing, and P-clip the hard line or block to it perhaps?
      SchwartzPerformance
      Jul 2009
      Cypress, TX
      Yes, and thanks for the suggestion, but we've already powder coated the rear end. I was hoping for a bolt-on solution. How do Ford production vehicles handle this issue?
      I dealt with this issue some years ago. I bent a bracket from steel strap that bolts under one of the carrier nuts and goes over the top (somewhat to the side) of the housing, placing the distribution block at a similar location as if it was bolted to one of the original rear cover bolts.
      67 Camaro, 96 LT1, 4L60E
      Jul 2009
      Cypress, TX
      Quote Originally Posted by red67camaro View Post
      Thanks, that's what I had in mind too, but I assumed Ford would already have created such a bracket. Anybody know?
      Jan 2013
      Las Vegas, NV
      This is what I used. It's from CPP. I ended up grinding off the 90* angle on the bracket and covering it with clear shrink tube.
      http://www.ebay.com/itm/REAR-STAINLE...42e18b&vxp=mtr
      This is the only pic I could find with it installed. Hopefully it will show what you're looking for.
      Scott Atkinson
      68 Camaro SS in progress
      Las Vegas, NV / Redondo Beach, CA
      Jul 2009
      Cypress, TX
      That'll work. Thanks for the help guys!
      Oregon
      Ford typically uses the breather vent fitting in the tube to attach the tee-fitting to the housing, so next best bet is one of the options noted above since your housing is painted already.
      It's what I does.
      Sep 2010
      Santa Clara, CA
      I'm pretty sure I'll regret it but I just used the stock Camaro piece on my '67 with a 9" (car is not functional yet). I may have had to drill out the hole in the bracket for the piece, but I think it pretty much fit otherwise? Probably mounted it at around the 2:00 position, looking from the rear of the car?
      Steve
