View Full Version : Ford 9" rear end bracket for brake line
terrydmorgan
06-17-2014, 11:14 AM
I need some help running my brake lines in my '69 Camaro. In the '69 Camaro rear brakes, a single hard line couples to a flex line that has a distribution block feeding two lines, one for each rear wheel. The distribution block bolts to an L-shaped bracket connected to a cover bolt on the rear side of the 10-bolt rear end. I have a Ford 9" rear end and the bracket for the distribution block doesn't fit well. Anyone have a suggestion on how to mount the rear brake line, particularly with respect to the distribution block.
Schwartz Performance
06-17-2014, 01:31 PM
Can you weld something like a nut or bung to the rear end housing, and P-clip the hard line or block to it perhaps?
terrydmorgan
06-17-2014, 04:02 PM
Yes, and thanks for the suggestion, but we've already powder coated the rear end. I was hoping for a bolt-on solution. How do Ford production vehicles handle this issue?
red67camaro
06-17-2014, 05:34 PM
I dealt with this issue some years ago. I bent a bracket from steel strap that bolts under one of the carrier nuts and goes over the top (somewhat to the side) of the housing, placing the distribution block at a similar location as if it was bolted to one of the original rear cover bolts.
terrydmorgan
06-17-2014, 07:29 PM
Thanks, that's what I had in mind too, but I assumed Ford would already have created such a bracket. Anybody know?
Scott Atk
06-17-2014, 08:59 PM
This is what I used. It's from CPP. I ended up grinding off the 90* angle on the bracket and covering it with clear shrink tube.
http://www.ebay.com/itm/REAR-STAINLESS-BRAIDED-CENTER-BRAKE-HOSE-WITH-TEE-FOR-3-16-LINES-/380461310347?pt=Vintage_Car_Truck_Parts_Accessorie s&hash=item589542e18b&vxp=mtr
This is the only pic I could find with it installed. Hopefully it will show what you're looking for.
terrydmorgan
06-18-2014, 03:45 AM
That'll work. Thanks for the help guys!
Apogee
06-18-2014, 11:45 AM
Ford typically uses the breather vent fitting in the tube to attach the tee-fitting to the housing, so next best bet is one of the options noted above since your housing is painted already.
sjaroslo
06-18-2014, 02:56 PM
I'm pretty sure I'll regret it but I just used the stock Camaro piece on my '67 with a 9" (car is not functional yet). I may have had to drill out the hole in the bracket for the piece, but I think it pretty much fit otherwise? Probably mounted it at around the 2:00 position, looking from the rear of the car?
