View Full Version : Question?
SILVERBK80
06-16-2014, 03:57 PM
I have a base model 1980 firebird with upgrades to the drivetrain and I would like to increase my stopping power with the lowest cost to my pockets. My question-Can i achieve this goal by upgrading stock front disc with larger rotors and larger calibers? Can I get by with this without changing the boosters? If so, what type or style do you recommend that is low cost to my pockets? In the future I would like to convert the rear drum to disc but for now I want to focus on the front. I do believe I have a size 11 in rotors on the front, i hoping to increase the size to 13in. Thank you in advance for your assistance! Any input you can provide would be deeply appreciated.
Silverbk84
a67
06-17-2014, 04:03 AM
The least cost option would be to install and bed some good brake pads. Something along the lines of StopTech Street Performance pads are a good choice.
Bob.
SILVERBK80
06-17-2014, 06:44 AM
Thanks Bob!
Skip Fix
06-17-2014, 06:46 AM
Any bigger rotors up front is generally going to need a larger wheel. The B body spindles for 12" (actually about 11.88) rotors can fit a 15" wheel. Using a late 80s early 90s Camaro 1LE rotor(or redrilling a B body rotor for 4 3/4 bolt pattern) will give you a little bigger rotor that can fit a 15" wheel if larger are not in the budget yet. That and a good pad.
The 96 Impala "police" D614 pad is larger that the stock D52 pad and will fit the caliper and can be used even on the stock 11" rotor. I know Hawk makes a D614 pad so they are available in a good pad. So as a67 said a good pad will help as well as soem good shoes. When I was running disc/drum with semi metallics back in the day I could still lock up the rears on heavy braking so an adjustable prop valve in the rear line can help tune in your system.
There are also companies that make a better performance drum compunds if you are keeping those.
SILVERBK80
06-17-2014, 05:54 PM
I will try this, thanks for your help.
SSLance
06-17-2014, 06:09 PM
I'm running EBCYellowstuffR brake pads on stock 10.5" rotors and a 2.75" single piston caliper and my car stops like crazy. The EBCs are a great street pad plus when it gets hot on the track it really starts to grip.
Apogee
06-18-2014, 11:50 AM
The easiest way to increase brake torque (stopping power) is to run a higher CoF compound pad, as suggested above. The easiest way to add brake capacity would be to increase rotor size, diameter and/or thickness. Given the application, you could opt for Skip's suggestion to swap over to a 12" nominal GM tall spindle and inherit the bigger brakes along with it, however given your location of Japan, that's probably not going to be as simple as heading down to a local wrecking yard.
What's the intended use for the car?
Tobin
KORE3
SILVERBK80
06-19-2014, 06:50 PM
My intentions is for street use on the weekends and possibly so track action. Thank you for your input.
