    Results 1 to 7 of 7
      Apr 2010
      Miami
      Hydro boost issues
      Well my Chevelle sat for a long time and I finally got it running. I was having issues with
      my stater and fuel injection. After I got all that sorted I went to drive the car and my brake
      pedal was pushing back when I depressed the pedal also the pedal very low. This was a new hydro boost that I installed
      just before the car was parked. I was working perfect.
      Is there something that could have happened because it sat so long?
      Any help will be appreciated.
      Apr 2010
      Miami
      I can understand injectors needing to be clean after long use but what could cause the hydro booster not working from
      Inactivity. Anyone have this issue.
      Apr 2010
      Miami
      Well I called Hydratech and they were very helpful and this is not their unit. Anyone look for Hydro boost you should look
      into Hydratech. Basically he said that I need to get the brakes working manually first and then look at the Hydro boost.
      This makes sense I need to get manual brakes first.
      thanks Hydratech!
      Dec 2002
      MusicCity
      Don't immediately assume...
      Your description actually sounds to me like more of a conventional brake problem as opposed to a problem with the hydraulic brake assist unit itself. My thoughts are that you should thoroughly bleed your brakes (especially from sitting so long / age), adjust up your rear brakes (if drum or calipers with integral e-brake). It is also possible that your master cylinder may be starting to ail (corrosion pitting inside the bores from moisture in the brake fluid). If that doesn't clear it up, read up further: http://www.lateral-g.net/forums/showthread.php4?t=27741
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
      www.hydratechbraking.com
      Dec 2002
      MusicCity
      I just hit send on my post above to find you had just spoken with my guy Jim - worth a good chuckle.
      Paul M. Clark
      Apr 2010
      Miami
      Started to work on the car, master cylinder no fluid passenger side rear wheel cylinder leaking.
      Front brake caliper bleeder screw broken, thought I try new set of easy out but I snapped it.
      Oh well at least not a big problem.
      Dec 2002
      MusicCity
      Have you gotten all of your bugs worked out yet? Failing rear wheel cylinder and front caliper bleeder issues?
      Simply curious as to your progress
      Paul M. Clark
