View Full Version : Second gen F body upper control arm weights
Skip Fix
05-26-2014, 05:26 AM
Thought I would post some info for you weight conscious folks. All are with ball joints and bushings.
Global West Drag arms 6lb 10.5oz
Pro Touring F body 7lbs 8.5 oz.
stock stock rubber bushings 9.0 lbs
Global West regular arms 9lbs 2.5 oz
The Global and stock arms have the ball joint mount slightly canted from the axis of the cross shaft, whereas the PTFB are straight as soem othe aftermarket arms are.
