View Full Version : LS6 intake on 383 stroker
JJ Cam
05-23-2014, 02:07 PM
I'm guessing not, but does anyone know if an LS6 intake and injectors will fit onto a chevy 383 stroker motor. Is there modifications to the block to make one fit?
Z06vet
05-23-2014, 04:18 PM
Is it an ls1 383 or sbc 383?
Schwartz Performance
05-23-2014, 04:57 PM
Intake manifolds bolt to the heads, not blocks. There's no possible way of fitting a gen 3/4 intake to a gen 1 or 2 small block.
LS6 intakes only bolt to ls1/2/6 heads.
-Dale
JJ Cam
05-23-2014, 05:16 PM
Yeah I just meant onto a gen 1 or 2 small block engine. So is there any way to put ls1/6 heads onto the sbc? Basically the top end of an ls6 onto the bottom of the small block? I haven't heard anything about it and don't know enough about the ls series engines and their components.
raustinss
05-23-2014, 08:24 PM
No...never in a million years would it work.
My question is why would you want to do that in the first place
garys 68
05-24-2014, 03:50 AM
Other than the bolt and port pattern differences, you'll have to drill a hole for the distributor......
srh3trinity
05-24-2014, 05:22 AM
I believe dart makes a block that takes gen 3 and up heads and intakes. I am sure it is pricey though.
67rally
05-27-2014, 12:35 PM
The intake/exhaust patterns are different too. SBC cam wouldn't work with LS heads/intake. You'd have to do a custom grind. Head bolt pattern is different, intake bolt pattern is different, header pattern is different...
I think it would be much easier/time efficient to swap an LS in place of your 383.
JJ Cam
05-28-2014, 09:39 AM
Yeah I figured it wouldn't work. I am completely happy with my current setup, just was curious.
