View Full Version : Pro touring hurst olds
DANIMAL340
05-19-2014, 07:19 AM
Hello - way cool web site !
I have a 1984 hurst oldsmobile. I was wondering if anybody new what size tires and wheels (with off set) i can fit under the car with out allot of modifications.the car does sit about 1-1.5" lower than stock - from what i have found: 245/45/17 front and 255/45/17 nittos will fit and a 4.5" back spacing on the rim.
Any help or pictures would be awesome - thanx
SSLance
05-19-2014, 07:30 AM
I'm running 275/40/17s on 17x9.5s with a 5.0" backspace on all four corners of my G-body with no rubbing anywhere. An aggressive alignment up front really helps with tucking the front tires properly to keep them from rubbing.
You can fit a 275/40/17 nitto out back with a 5.0" backspace very easily with maybe a 1/8" spacer is all.
How did you lower the front, drop spindles or shorter springs?
DANIMAL340
05-19-2014, 08:02 AM
It has 1" shorter spings - I would like a little skinner in the front - whats your thoughts ?
Im assuming you dont have stock suspension either ?
bonspeedbrad
05-19-2014, 10:55 AM
I have helped a number of customers with the G body cars and can help you fit 17's 18's or 20's.
I have personally owned both a Monte Carlo SS and a Grand National Buick so I know them very well.
Call me 714.666.1999 www.bonspeedWheels.com
SSLance
05-19-2014, 11:21 AM
I've had several different suspensions on my car but currently it's on ridetech coil over shocks and front lower control arms.
Drop spindles cause some tie rod end clearance issues with some wheels is why I asked, if on stock spindles you are good.
Here is my car last year with 2" drop springs all the way around, 275/40/17s on 17x9.5 5.0" bs rear, 245/40/17s on 17x8 4.5" bs fronts
https://static1.pt-content.com/images/pt/2014/05/20130525JohnHiattIV06623-1.jpg
Pretty common setup for a G-body.
DANIMAL340
05-19-2014, 01:18 PM
looks awesome - I am looking at just a driver that looks way cool - I just want to put the wheels and tires on it and drive it. Maybe newer front and rear sway bars. Just not get crazy with suspension. Do you think the thread I started with size would look good or even go with a little wider in the back. You have been very helpful (thank you)
silvermonte
05-19-2014, 02:33 PM
If you havnt bought the rims and tires yet I would go with the 275s on all four corners.
qnitro
05-19-2014, 03:06 PM
I'm getting to pull trigger on a 1987 Grand National.. I was curious if I could get a 18x10 rear, with. Notch
bonspeedbrad
05-19-2014, 04:31 PM
Yes, I can fit an 18X10 under a Grand National without any modification and no rubbing.
Give me a call, plus we are now having a Buy 3 Get 1 Free Sale!
714.666.1999 or 714.666.1966 www.bonspeedWheels.com
csouth
05-19-2014, 05:18 PM
Glad you took my advice and checked the site. Plenty of g bodies with aggressive wheel and tire setups here to compare.
DANIMAL340
05-20-2014, 03:58 AM
Holy smokes - you guys are awesome. Myles to you have a picture of your 88 cutlass with the 17" ?
83hurstguy
05-20-2014, 08:45 AM
As a heads up, regal and cutlass have a flat lip on the front inner fender that takes away an extra 1/2" of space or so. On a severely lowered car you end up going to a shorter tire to go wide, cutting the inner fenders, or sticking with a 245/255 width. A lot of people claim you can put a ton of tire in there, then have 2 inches of space above them riding like a 4x4. Always be cognizant of ride height vs fitment. That comment wasn't directed at anyone in this thread, just something I learned in general about internet wheel fitment advice.
