    Results 1 to 16 of 16
      May 2014
      Ft. Collins, CO
      Best brakes, A-body, 15" wheels?
      What are the best brakes for an A-body with 15" wheel restriction? Looking for reliable DOT stuff that can be driven for years on end without maintenance...probably nothing with an aluminum hat or hub. Anybody have experience with SSBC Super Twin calipers vs. Wilwood D52 vs. iron D52?
      Nov 2013
      near Charlotte, NC
      How about factory front disk for taxi, police car, or station wagon? Are you talking about GM or Mopar? Year?
      Conrad
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      Apr 2012
      Woodstock, IL
      Don't go SSBC, keep it oem (Corvette etc) or Wilwood / Baer. Also what's your budget?
      -Dale
      SchwartzPerformance
      Jun 2006
      Katy,TX
      s-10/Blazer rear discs. Lots of places have all the parts listed to do this.
      Front should be able to use an A body disc setup as they had them form '67 up(67s used 4 piston calipers liek C2 Vette calipers, 68 and up a single piston). For a bigger 12" rotor the 12" B body spindle and a B body or 1LE rotor and a D52 caliper. The Wilwood D52 calipes are bulkier than a factory iron style.
      Most of the C4 or C5 Vette front kits or siilar Baer PBR kits require a larger wheel usually even a 17 and not all of them fit. My 16" Trans Am GTA wheel do not fit a 13" Baer kit.
      15" are the liniting factor here.
      1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
      1981 Trans Am 400 stock type motor
      79 Camaro getting a 500" 695 hp IA2 Pontiac motor
      1965 GTO project car
      470ci/Chevy dual quad 409 604 HP 64 Impala SS project
      2004 Pulse Red GTO
      May 2010
      kitchener,Ontario,Canada
      Use the B body conversion which you can then use camaro 1LE 12" rotor....for the rear either the s10 conversion of use 77-79 Cadillac Seville rear disc option....brackets with 79-81 ws6 rotors
      Good. Luck
      Ryan Austin
      On Instagram ryanaustinss70
      Apr 2010
      Pittsburgh, PA
      I have Wilwood dual piston D52 calipers with 94-96 impala SS D614 Pads direct swap for factory GM disc cars .
      Stops well, even fits 14in steelies
      I know theirs a 4 piston that'll clear a 15, but dont recall if it was Wilwood or Baer ..most likely both offers a kit like this
      72 buick skylark
      twin-turbo fuel injected buick 350..perhaps stroked to 370 in the works!
      Jun 2006
      Katy,TX
      Most of Wilwood's kits that fit 15"s use a small rotor and their dynalite caliper which has a really small pad.
      I think Wilwood has some kits using the D154 rear calipers that kind of match the D52 calipers and use an internal E brake.
      2004 Pulse Red GTO
      Aug 2010
      now In Dandridge, Tn.
      If you can swap in 12" Impalla rotors, or the 1LE 12", that will help, but don't give up clamping force. Try using a set of Howe steel D52 single piston calipers. They are lighter that stock GM, and have a 2.937" dia. piston, thats 9.22 sq.in. of piston surface. - More than any other common caliper, OE or aftermarket. Pt # 337. ($69.00) match with Hawk # HB100c pads. This on 11" rotors will out brake almost any 'big' brake set up.
      Jan 2013
      Cypress, California
      I agree with the above. As stated the right brake pad will go a long way in improving your stopping power.
      Waterloo, Ia
      In all honesty with 15" wheels, the good old Right stuff Detailing stock GM 11" D52 front and 11" Eldorado rear have done just fine for me. I'm upgrading to bigger wheels and brakes so these will get sold soon but they have worked just fine the last 3 years and have quickly pulled my GTO down from over 120mph without any issue.....of course this was on a closed road with a professional driver.
      -Nick
      -1967 GTO I drive and race
      -Build threads:
      Jan 2013
      Ssbc
      Why do you say stay away from SSBC?
      Jul 2013
      St Louis
      I would stay away from SSBC. I bought there $350 master and it leaked like crazy at the piston area. I checked everything several times and finally after it drained itself dry a few times on my frame I sent it back. Of course they couldn't find anything wrong with it and made me pay for return shipping. Funny how it never leaked again after I got it back. Overpriced + bad service = never again for me
      Wilwood on the other hand has been great to work with. I installed the D154 calipers on the rear just the other day. Those are a stock metric replacement and use a stock 11" rotor so they should fit 15". The D52 is the SAE version.
      Pontiac Powered 72 GTO
      Jan 2013
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      what baer brake i need to go with on my car i have 18 on it and my budget is about 1500-2000
      Jan 2013
      Cypress, California
      "In all honesty with 15" wheels, the good old Right stuff Detailing stock GM 11" D52 front and 11" Eldorado rear have done just fine for me."
      Same here. I did install the EBC Red Stuff brake pads to get the stopping power I was looking for. In the meantime I went to 17" wheels but kept the brakes as they are working just fine. This is on a 1965 Buick skylark.
      cookeville, tennessee
      I have the bbody spindles w/ 1LE rotors, stock calipers in the front and 76 Eldorado calipers w/ 11" '79 WS6 TA rotors. It works fine on the street I've never auto crossed it or anything of the sort. HTH
      Jake
      Dec 2002
      MusicCity
      Knock your socks right off with OE disc / drum brakes
      You would truly be blown away beyond belief as to what the factory disc / drum GM A body brakes can do when in a proper state of service combined with one of our hydraulic brake assist systems (if you have properly functioning power steering):
      http://www.hydratechbraking.com/GM_A_Body.html
      Truly mind bending performance without even touching brake fluid (when swapping in one of our systems in place of an existing vacuum booster).
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
