View Full Version : C6 Vette Upper & Lower Control Arm Bushings
Cdog
05-05-2014, 07:23 AM
I need of some advise on what is recomended for replacement A-Arm bushings on C6 Vette/Art Morrison Camaro G frames. Poly? Delrin? Solid? Bearings like Steve Rupp did on Penny? The car is being built to compete. I’m willing to deal with a rough ride on the street to eliminate deflection on the track. Where can I get just the fronts without having to buy the whole kit?
Thanks in advance.
A-Arm Porn.
95142
srh3trinity
05-05-2014, 07:33 AM
I have some poly for mine but my car is going to be more street and haven't changed them out yet. I never could find a good consensus. The Pfadt stuff got high marks but was too pricey for me. I think mine are prothane
parsonsj
05-05-2014, 08:10 AM
Delrin all day long, and twice on Sunday.
Phoenix Performance in Pennsylvania can fix you up, as can Van Steel in Florida. It requires honing to fit, so most of us C6 guys send 'em off, rather than do them ourselves.
Cdog
05-05-2014, 08:41 AM
Thanks! I saw them mentioned on a vette forum and lol'd at their price. Hopefully they will sell me the parts without install.
DJW32
05-06-2014, 04:57 PM
Quick bump.
Has anyone tried pfadt poly bushings?
marolf101x
05-06-2014, 05:13 PM
We built a set of Delrin bushings for Herb for his Mock front end. Maybe there's a market for these?
I'll post some pics tomorrow.
Cdog
05-06-2014, 06:01 PM
Sounds great! Should I send you my A-Arms so you can do a build thread on them?:cheers:
marolf101x
05-07-2014, 03:53 AM
We didn't machine the arms at all. We just pushed out the OE bushings and made Delrin ones to fit.
Here's a quick screen shot of the front upper. . .uses one long Delrin bushing per mount and a fabricated trunnion:
95224
Here's a screen shot of the front lower. . .uses two bushings per mount:
95225
parsonsj
05-07-2014, 04:28 AM
Britt,
If you guys go to market, you might consider making the UCA trunnion depth asymmetric. By that I mean that one side of the trunnion adds more camber than the other. By rotating the trunnion and bolting it on from the other side you can add or subtract camber. Offsetting the trunnion about 12mm (.5") should be possible. Also, slotting the holes to add caster would be most welcome. Oh: and a provision for adding grease.
That's my wish list, anyway. :)
jp
marolf101x
05-07-2014, 06:04 AM
No need for grease. We use delrin with Teflon.
Yelcamino
05-07-2014, 11:46 AM
Here are some shots of the delrin bushings installed...
Uppers
https://static1.pt-content.com/images/noimg.gif (http://s263.photobucket.com/user/hlumpp/media/Chevelle/Mock%20Frame/IMG_20140220_181511_749_zps46205720.jpg.html)
One of the lowers
https://static1.pt-content.com/images/noimg.gif (http://s263.photobucket.com/user/hlumpp/media/Chevelle/Mock%20Frame/IMG_20140220_181523_034_zpse69e8007.jpg.html)
I can get more pictures/closeups if anyone is interested.
Cdog
05-07-2014, 12:03 PM
Those look good to me. So what's the damage?$$$
efs69
05-07-2014, 02:51 PM
Interested as well.
marolf101x
05-07-2014, 03:47 PM
I don't have a price. . .yet. We built a set for Herb, and while I was at it we printed all the parts just in case others wanted the same thing.
Let me run it through production and get some pricing together.
I'll let you know as soon as I can.
Cdog
05-07-2014, 04:30 PM
Thanks! I'll probably be in for two sets depending on price.
Ron.in.SoCal
05-09-2014, 11:35 AM
Britt I'd be interested in a price as well. Front upper and lowers only. Thanks!
Cdog
05-14-2014, 03:56 PM
Britt, What’s the word on these bushings?
marolf101x
05-14-2014, 04:11 PM
I'm working on costing now. Delrin with PTFE (Teflon) is about 10 times more expensive when purchased in rod form than non PTFE (Delrin with PTFE is brown. The cost is why we chose to injection mold our Delrin bushings for the "old" cars, and why you typically see white Delrin used by most manufacturers who machine their bushings from rod stock)
I have some basic costing together, but the Delrin rod is quite expensive. I'll post up the pricing when I get it done. To get a little better I have to locate a better source for material, which will lower the cost.
I'll post it up here when I have better info.
I am on it and will have something soon!
Cdog
05-14-2014, 04:45 PM
Thanks Britt!
efs69
05-16-2014, 09:33 AM
thanks britt!
x2!
marolf101x
05-16-2014, 10:13 AM
Ok guys. . .
As it sits right now here's the kit:
Front Upper Control Arms:
-two self lubricating Delrin bushings per arm
-two "dogbones" per arm (these are straight CNC-ed trunnions that are slotted. . .I'll look into offset later as I need to make sure the arm will not contact the frame when pushing the arm inward)
-four washers per arm
-4 snap rings per arm
Front Lower Control Arm:
-two "small" bushings for the forward mount
-two "large" bushings for the rearward mount
Bushings are direct fit into OE control arms:
-no machining required
-no lubrication zerk required
Complete kit for the front will be right at $500.00
