View Full Version : How do I support my Bird to replace body mounts ?
Gil
04-24-2014, 02:39 AM
Hi Guys,
Here is the nooby question.
I have 4 jack stands, 1 hydraulic jack and a bottle jack.
Here is what I have found, do you think it's correct ?
So 2 under the rear axle and 2 under the rear of the subframe by the transmission crossmember ?
Do I need 2 more jack stands to put under the front of the subframe by the bumper ?
Then use a jack and block of wood to raise the body enough to change the mounts ?
Change one side at a time & loosen only the side you change ?
Do you think it's correct & how do you do it if not, please ?
Thank you very much
Gil
04-25-2014, 07:49 PM
One side at a time, but loosen all bolts.
Jack stands under the rear axle.
Place a jack stand under each rocker panel, place a foot long 2x4 between stand & rocker, they are easily dented, push the 2x4 up against the pinch weld. Support rear of subframe on one side & loosen all sub bolts a turn or two. Loosen or remove the bumper brace bolts at the frame, monitor fan to shroud clearance & remove the fan if it hits. Check distributor cap to firewall, you may have to pull the cap, but that's usually ok on a sub mount R&R.
Remove the rear bolt & lower jack enough to change the mount, you may have to loosen the other two bolts more. Install a new bolt, tighten a few turns then move to the middle mount, repeat, then do the front. Repeat on other side, but keep an eye on the fuel & brake lines at the rear of the subframe. re-center the sub using the alignment holes on each middle mount.
On the left side watch the steering rag joint & don't separate the sub too far. Loosen the steering box frame bolts if the rag joint is stressed.
Rod
04-25-2014, 09:12 PM
Place a jack stand under each rocker panel, place a foot long 2x4 between stand & rocker, up against the pinch weld. Support rear of subframe on one side & loosen all sub bolts a turn or two. Loosen bumper brace bolts at the frame, monitor fan to shroud clearance & remove the fan if it hits. Check distributor cap to firewall, you may have to pull the cap, but that's usually ok on a sub mount R&R.
Remove the rear bolt & lower jack enough to change the mount, you may have to loosen the other two bolts more. Install a new bolt, tighten a few turns then move to the middle mount, repeat, then do the front. Repeat on other side, re-center the sub using the alignment holes on each middle mount.
^^^^ this
Gil
04-27-2014, 12:45 PM
Thank you VERY MUCH David (& Rod).
I'll have to translate in French carefully first as it is very technical & will have to be very carefull also when I do it.
I really love this site for this........... So nice......
I'm really honored I (a French guy with little skills & few tools) can chat with a racer & I can learn from him....
Haven't got the words in English as I'm not very fluent but thank you very much to read & take from your time to answer & share your knowledges.
So cool that gives me the big motivation to work on my car.
Have a nice day guys
Gil
71beast
04-28-2014, 09:18 AM
Not to hijack this thread, but should a similar method be employed for those of us with full framed cars? Cause I'm looking at replacing my Chevelle's body bushings and not 100% sure how to do it properly.
Gil
05-15-2014, 12:18 AM
Hi there newby question again about torque specs for my factory rubber body mounts, here is what I found, do you think it's correct for the first gen. F body ?
4 body to frame mounts 75-95 lbs ft
2 core support to frame mounts 30-40 lbs ft
Thanks again guys
Gil
TRANSAMERICAN 79
05-22-2014, 03:52 AM
I found this very helpful. Spray some PB blaster days prior to removal attempt, mines came out really easy without any issues.
Gil
05-03-2015, 11:15 PM
Heard that stock radiator core suport was subject to crackings when using solid body mounts ? Myth or not ?
is it relevant to mix with front poly bushings for the rad. suport to avoid cracks & use solid alu. for the four other holes ?
Gil
Gil
01-31-2016, 08:58 AM
Hello all,
Before starting the body bushings replacement the driver side frame alignment hole wasn't centered,
Then I replaced the bushing & the alignment hole still not centered,
but I measured diagonally from a hole @ the front of the leaf springs to a hole @ the core support
then another measure from the holes @ the front of the leaf springs to the frame alignment holes
and frame is squared...
is it an issue that the driver side frame alignment hole is not centered?
Gil
