View Full Version : Baer Brake (Track4)
bishir
04-17-2014, 07:49 AM
I ordered Baer Brakes (Track4) and it came with the hub and spindle included and ready to go..
The wheel studs are a bit short. I'd like to order before I pull it apart, are they stock sized push in studs?
Application: G-Body (87 Buick GN)
Schwartz Performance
04-17-2014, 09:51 AM
They're not stock size.. If you want longer ones Baer sells some ARP that are 3" long, but they're $10 each.
You should call them for the info and to order.
-Dale
bishir
04-17-2014, 10:00 AM
Thanks for the info Dale I guess I'll give them a call. I'm assuming they're press-in then right?
I would also like to add that I found out the billet dust cap can cause interference issues with certain rims. If you every need a replacment dust cap you can order Dorman # 618-102 for the appropriate stamped steel version.
