View Full Version : Setting vent window glass
gtotto
04-09-2014, 06:51 AM
Hey guys
I need to install new vent glass into their chrome frames and was wondering on the best method. I've done a search a found a couple of guys recommending RTV over setting tape. I've never used setting tape so I don't know how easy or difficult the process is. The RTV sounds simple enough but when I test fit the new glass I find there to be a lot of side to side play. If I used the RTV would I try to center the glass in the frame while the sealant cures or push the glass closer to the interior or exterior side??
Ken
lzdick
04-09-2014, 09:59 AM
The tape (or sometimes rubber) serves as a shim to alleviate the movement you are experiencing.
DirtShark
04-09-2014, 01:32 PM
I used clear silicone on mine with very good success. Gives you ability to get the glass right were you want it and let set up.
gtotto
04-09-2014, 04:23 PM
It seems like the RTV may be the way to go. Thanks
perry mitchell
04-13-2014, 07:57 AM
I got some setting mateial from a local automotive glass shop to set the glass into the frames on my 57 Chev. It comes in several different thicknesses. You coat the material on both sides with a film of oil which helps with the installation. As the material soaks up the oil, it swells. The extra material is then trimmed of with a razor blade. I was told this was the way the factory did it back in the day.
Jetfixr320
04-13-2014, 08:01 PM
I also used setting tape.
dhutton
04-14-2014, 03:59 AM
I used the setting tape. RTV is nothing but a dirt magnet in my experience and will likely look bad over time.
