View Full Version : Type 2 pump reservoir removal
musclecarmatt
04-05-2014, 09:17 PM
Hey guys,
I'm about upgrade my power steering to remote reservoir, I have the DSE cast iron pump with reservoir isn't the reservoir just held on by couple of tabs or clips?
Matt
Schwartz Performance
04-05-2014, 09:53 PM
A couple spring clips need to be removed then it'll come off with a good pull
-Dale
csouth
04-06-2014, 10:00 AM
Hey guys,
Matt
I tried tapping the return side of my Type II pump and couldn't get my tap in deep enough with the way it was made. I'm thinking of buying the DSE pump now that's already tapped with fittings.
dontlifttoshift
04-06-2014, 10:24 AM
Yep, reservoir removal is the easy part. Leave it together and sell it as a package, buy a new pump already set up for remote reservoir.
Why go remote? I've done it both ways and prefer an integral reservoir.
musclecarmatt
04-06-2014, 11:59 AM
the main reason thinking about upgrade is having trouble with fluid spewing out of vent in the cap at the top when running high rpm for long periods of time...the fluid level is correct and im using Joe Gibbs Racing Power Steering fluid....not having any power steering fade when hot....either need remote reservoir or a cooler made the fluid still getting too hot....I have heard problems with the 600 steering box with recirculating valve causing overheating problems
1970 TT Rustang
04-06-2014, 06:02 PM
I have 2 gm type 2 pumps for sale one used with a flaming river rack and one new from gm and a flaming river remote resevior. I went with the dse
