View Full Version : 1970 Camaro Sub-Frame
badazz81z28
03-17-2014, 06:27 PM
Suprise to me....one of the rubber bushings rotted out one of my frame mounts. Looking for a subframe.
badazz81z28
03-18-2014, 10:03 AM
Wow...84 views and no replies. I suspect people are confusing this "wanted" for a a "for sale" lol
I know quite a few of you all 2nd genners have DSE frames....where are the stockers?
71maroesteban
03-18-2014, 03:34 PM
Your gonna have to most likely settle for a late second gen sub frame the 1970-73 are impossible to find I've tried and they don't make repo ones
regal454
03-18-2014, 03:50 PM
How bad is the mount, can it be repaired? You can buy the hole repair kit like this:
http://www.carid.com/1967-chevy-camaro-chassis-frames/goodmark-frames-2020389.html
Plus, this is another excuse for you to buy a new welder!
bretcopsey
03-18-2014, 05:27 PM
My 68 Camaro frame rotted out at the firewall mounts. It was an easy fix with some large washers-just welded them in, can't even tell once the welds were finished.
badazz81z28
03-18-2014, 07:59 PM
Research has informed me that the 75-81 frames are different. The rust isn't bad...but I suspect the labor would be more than a replacement.
Goosesdad
03-18-2014, 08:01 PM
I have a 70 that I am getting ready to disassemble for a full PT suspension. Will have a straight subframe for sale.
71maroesteban
03-19-2014, 01:07 AM
The differences are that huge and another plus is the later second gens suspension handle a lot better
badazz81z28
03-19-2014, 05:35 AM
From what I understand the frame holes are not in the same spot. It physically will not bolt on.
71maroesteban
03-19-2014, 07:58 AM
It'll bolt on but you just have to re drill the holes I believe look over at nastyz28 they talk about how to do it
frojoe
03-19-2014, 11:12 AM
I'd recommend fixing what you have, unless you have doubts about the straightness or strength of the welds on the rest of it.
I too had a rusted-out mount hole (on my Nova subframe), check out my post for how I fixed it...
http://ls1tech.com/forums/11894174-post163.html
