View Full Version : 1986 Buick Pro-touring T-Type
xxxturbo6
03-07-2014, 07:39 AM
Well the time has come to sell our test car and move onto another project. This car has been to Many ASCS pro-touring events and has been seen by Many here on this board at those events that can vouch for the car and it's performance. This car drives as well as it looks!
If you have any questions or would like to see more pictures please shoot me a PM and I will give you my number...
$32,000
For video of the car in action please visit us on Youtube: http://www.youtube.com/channel/UCqRCQUhhK3Yz-kNqmdHQ7gw
For detailed suspension/Brake pic's see links below:
BAER Brake Install thread: http://www.turbobuick.com/forums/threads/baer-brake-install.343546/
DSE Suspension Install Thread: http://www.turbobuick.com/forums/threads/complete-dse-suspension-build.329141/
RideTech Tru-Turn & Shock Install Thread: http://www.turbobuick.com/forums/threads/ridetech-g-body-tru-turn-coil-over-install.397417/
1986 Buick T-Type Specs’
Engine: Freshly Balanced & Blueprinted by Richard Clark & Myself (2012)
I have the blueprint sheet that Richard Clark & I did showing all measurements of the engine!
J&E Pistons .20 over with J&E file fit rings done by myself
Carrillo “H” beam rods w/ ARP L19 rod bolts
Seal Power bearings (2012)
ARP Main studs – New (2012)
ARP Head bolts – New (2012)
Stock heads w/ stainless steel valves & new Viton seals – New valve job ( 2012 )
Alky Control Progressive Methanol injection – New Pump in 2012
H&R Poly motor mounts
55lb Injectors – (Matched & Flowed)
TE-44 Turbo w/ Garrett exhaust Housing – Freshly rebuilt by "Bison" (2012)
Blue printed Oil Pump by Richard Clark – New in (2012)
Comp Cams 206-206 flat tappet cam – New in (2012)
Eastern Performance Front mount Inter-cooler
3” Stainless Steel down pipe with RJC waste gate puck installed
F-body aluminum radiator
160* T-stat
Intrepid Dual fans
Built 2004r trans, 500 boost valve, billet servo, alto clutches.
Protorque 3000 stall (Spragless) Non lock up converter w/ all fins Tig welded
GNS Cold air intake
LT1 MAF
Stock Ignition with custom fit MOROSO Ultra 40 wires
Extender programmable chip
Translator Plus programmable box
GNS Carbon Fiber Core support braces
Custom one off baffled oil pan by RJC Racing for Auto-X / Road racing
Power logger data saving software installed onto OEM computer
New Quick Ratio steering box (2012)
Exhaust system:
Dual ATR 3” stainless steel exhaust with Pit bull mufflers
Interior:
Pro-car Elite 1100 seats by Scat with custom Suede inserts
Suede head liner
Suede upper door panels
Stock rear seats custom upholstered to match the fronts
Suede rear deck lid
Whole interior dyed black
New black carpet
Custom made GNX style dash with white faced Phantom Auto-meter gauges and LED lights as turn signal markers. Also has the ALKY turn on and low level lights built into the face of the dash cluster.
Pioneer stereo with remote (New 2013 )
Rockford Fossgate Component speakers & Tweeters in front. (New 2013)
Pioneer 3-way speakers in rear deck lid. ( New 2013)
Scan master
Suspension:
Front- Ridetech's NEW “Tru-Turn Upper & lower A-arms (with Delrin bushings) with caser tuner slugs. (New 2013)
Front- DSE frame braces
Front- DSE Sway bar
Front- Ridetech Single Adjustable Coil Overs (New 2013)
DSE - Steering Shaft
Rear-Ridetech Single adjustable Coil Overs (New 2013)
Rear- DSE Upper adjustable control arms (with DSE’s swivel link ends)
Rear- DSE Lower adjustable control arms (with DSE’s swivel link ends)
Rear- DSE Sway bar (Chassis mounted & adjustable)
Wheels & Tires:
Made by CCW (Classic Custom Wheel) 3pc racing wheels – weigh 20lbs ea.
Centers were black brushed anodized along with the center caps
All locking black Gorilla lug nuts
Front: 18” x 9.5”- 4.75” back spacing
Rear : 18” x 10” - 4.75” back spacing
TIRES
Front: BFG KDW2 255/35-18 ( New Sept 2013 )
Rear: BFG KDW2 295/35-18 ( New Sept 2013 )
BAER Disc Brakes:
FRONT- BAER Track 4 featuring 13” rotors with 4-piston calipers, new OEM spindles, new bearings, stainless steel lines.
REAR- BAER SS4 system featuring 12” rotors with 4-piston calipers, Emergency brake set up, braided Stainless Steel lines, new e-brake cables
BAER proportioning valve
GNS Proportioning valve bracket
MCSS Vacuum brake system
Special Features: These items were done by us (GNS Performance) as this was our test bed for many products….
Tabbed smoked headlight covers
Custom trunk upholstery
Smoked marker light covers
Sequential LED Taillights (Not just bulbs either, these are actual boards with 187 LED’s)
Amber LED front Marker/Signals (Same style as above)
LED 3rd brake light
Custom made emblems inside & out on the car
Brake proportioning bracket
Translator plus bracket
Carbon Fiber Line-Loc bracket
Headlight screens for both the inner headlights (For cold air entering for the intake)
Tachometer/Alky bracket (Holds either a Tach or the Alky controller)
Carbon Fiber radiator top plate
GM High Tech Performance - May 2011
91492
Cover of GM G-body Performance
91493
DSE Add car for G-Body line
91494
91502
91501
91507
91508
91510
91513
91516
91528
91529
andrewb70
03-07-2014, 07:42 AM
Price?
xxxturbo6
03-07-2014, 07:50 AM
Price? Pretty fast with the gun there! I wasn't done editing ....
reedld
03-07-2014, 03:48 PM
Wow...that car ROCKS! I love GN's....love the white! GLWS!
subtlez28
03-07-2014, 08:05 PM
If I had $32k laying around, I would not hesitate. Very tasteful build!
xxxturbo6
03-08-2014, 07:42 PM
Thanks for the kind words guy's..... The Only reason for selling is to start a new project otherwise I wouldn't even think about it..... The money, time, effort in this car is far north than what I'm asking, someone will get one hell of a car for the money! This car has finished 30th or so out of the last several ASCS pro-touring events which had 80+ cars entered. The driver is holding it back! LOL
carguykeith
03-08-2014, 09:15 PM
Man I love this car, good luck with the sale! In case anybody doesn't think so, this is an amazing deal. I know I have north of $25k in mine doing EVERYTHING myself including paint/ body-work and this is A LOT more car!
SS PUNISHER
03-09-2014, 05:46 PM
Totally worth the 32k
GLWS!
xxxturbo6
03-10-2014, 09:32 AM
People like Bill Howell, Yancey Johns, Brian Finch, Danny Popp, Kyle Tucker, Doug Lutes... have all been in this car and know this car pretty well and can vouch for it if anyone is wondering who they can speak to about it..
72BBSwinger
03-10-2014, 07:37 PM
That is a smoking deal, if I could I would be driving it home NOW! AND its fricken WHITE to boot!
rayy
03-11-2014, 05:53 PM
What are kidneys going for these days??
rayy
03-12-2014, 06:42 PM
I want this car!!!!
xxxturbo6
03-14-2014, 08:24 AM
I want this car!!!!
It's here waiting on ya! LOL
xxxturbo6
03-17-2014, 04:21 AM
Bump to the top....
Scott Parkhurst
03-17-2014, 12:38 PM
Great deal for someone! Good luck with it Scotty!
xxxturbo6
03-18-2014, 11:38 AM
Great deal for someone! Good luck with it Scotty! Thanks Scott !!
xxxturbo6
03-20-2014, 04:07 AM
Bump to the top...
SicMonte
03-20-2014, 07:20 AM
Sad to see this go.......DONT DO IT!!!!!!!
This is an amazing car for the money!! (do you take payments?)
xxxturbo6
03-22-2014, 09:47 AM
Open to offers!
flyinbrian
03-23-2014, 07:59 AM
Good luck with the sale on this!
I've looked at your car over and over in the past, following the build, etc. because I had a GN for a brief time when I was younger and have always wanted to get one back in my hands, and yours is definitely the way I'd want to build it.
If I didn't have a '70 SS/RS Camaro with all the same Detroit Speed goodies you have in the garage, I'd be beating down your door! I just don't have room for both!
I know projects come and go, and I'm sure your ready to move on, but whoever gets it from you is LUCKY!
All the best!
xxxturbo6
03-24-2014, 04:17 AM
All the best! Thanks Brian!
xxxturbo6
03-28-2014, 04:56 AM
Bump....
xxxturbo6
04-01-2014, 05:52 AM
Bump..... Accepting reasonable offers!
rayy
04-02-2014, 05:08 AM
You sure you don't need a 67C10????
xxxturbo6
04-02-2014, 05:50 AM
Send pictures and the price on the truck to [email protected]
rayy
04-03-2014, 05:28 PM
Did you get the email??
xxxturbo6
04-07-2014, 02:26 PM
Did you get the email?? Yes I did Ray, I have two guy's coming to look at it on the 10th & 11th....
bishir
04-12-2014, 09:35 PM
If I weren't building the black version of this car I'd get this with no hesitation. Much cheaper than building one yourself! I'm still considering selling my 70 Chevelle to buy this to have a black and white version. ;)
xxxturbo6
04-13-2014, 04:22 AM
Sold!
SS PUNISHER
04-13-2014, 07:46 PM
Kinda makes me sad :(
hope we get to see it around the forum in the future.
PT Sportwagon
04-18-2014, 06:43 AM
Would you happen to need a 16 year old game geek? Naw His mother wouldn't go for it. Come on lotto
Tim
ChevelleSpeed
02-25-2015, 01:15 PM
Open to offers!
Still for sale?! Just PM'd you. Can we chat if it's still available?
Cheers
ChevelleSpeed
02-26-2015, 06:08 AM
My Bad, just read further.
Cheers
Car-Couple
09-12-2015, 09:11 AM
Is this still available? I am new to the site looking for a pro touring build and liked what I read above on your car. For some reason I cannot PM you so if you would email me a number I can reach you at would be great. [email protected]. Thanks!!
xxxturbo6
10-02-2015, 07:54 AM
Please read post #29 .............
