View Full Version : Body mount repair
paulk68
02-24-2014, 12:32 PM
Hello all, I pulled my front subframe and bushings out today and was dissapointed to see the condition of the body mount holes. Are these even repairable? if so how?
Paul
mikey
02-24-2014, 08:59 PM
Yes it's easily repaired. I think it's classic that sells a patch panel. You can also locate the center cut out the rusted area weld In a patch then use a hole saw to make a new hole.
gotyorgoat
02-25-2014, 04:39 PM
I just cleaned the rust off, primed it and then welded a washer over the top. If I remember, I special ordered a 1 5/16" fender washer which was a true 1 3/8" hole.
I tried the hole saw approach, but my cheap hole saw was immediately flattened. I figured the washer was an easier solution
67goatman455
02-25-2014, 10:08 PM
i did the same as the person above. they sell washers exactly for that
paulk68
02-26-2014, 05:46 AM
Thanks for the ideas guys, i found some plates as well, i wonder what would be my better option
a67
02-26-2014, 05:54 AM
Another way to go, make the repair 'washers' thick. Such that they become the body mounts. This kills two birds with one stone. The holes are repaired, and no separate body mounts are required.
Bob.
NOT A TA
02-26-2014, 06:14 AM
I usually use washers from the local Fastenal. If you can only use them on the outside you won't need to modify the body mount thickness. If the core support us rusty I make a sheet metal patch for top & bottom, plug weld & drill hole.
https://static1.pt-content.com/images/pt/2014/02/002_zpsb6c7f846-1.jpg (http://s240.photobucket.com/user/NOTATA/media/002_zpsb6c7f846.jpg.html)
https://static1.pt-content.com/images/pt/2014/02/013_zpsf405c783-1.jpg (http://s240.photobucket.com/user/NOTATA/media/The%2014%20Car%20Performance%20Therapy/013_zpsf405c783.jpg.html)
https://static1.pt-content.com/images/pt/2013/10/006_zps772685d0-1.jpg (http://s240.photobucket.com/user/NOTATA/media/The%2014%20Car%20Performance%20Therapy/006_zps772685d0.jpg.html)
