View Full Version : Window Tint
Norwoodx55
09-12-2005, 03:57 PM
I'm looking for a good (easy)way to remove window tint. Anyone have some good tips? The tint I want to remove is some cheezy, silver, 15 year old crap.
Thanks in advance,
Brett
paulk68
09-12-2005, 04:26 PM
razor blade, find a corner to start in and work from there.
derekf
09-12-2005, 04:40 PM
Seems like humidity/steam/moisture does it - let a car with tinted windows get a bit moist on the inside, leave it closed up while the moisture evaporates and re-condenses.. the tint will come off whether you want it to or not.
Might take a little longer than you're wanting to wait, unless you've got one of those portable steamers.
dropit69
09-12-2005, 05:43 PM
ive taken lots off ..razor blade and plenty of water in spray bottle..keep it wet..it helps alot..
vanzuuk1
09-12-2005, 05:53 PM
go to the hardware store and get a 3 inch razor bade with a long handle, its usually in the paint department.The handle lets you use two hands , its way safer and easier.Use a lot of windex or soapy water to keep everything slippery. take off long strips an inch or two wide, if the blade stalls your taking off too much at once. I have removed window film from 20 foot tall windows so I have done my homework on this one.
Stay away from the razor blade in the hand method unless you like the emergency room.
toxicz28
09-12-2005, 07:06 PM
I've used a razor blade and an alcohol :cheers: based window cleaner. I think it was "clear vue" or something like that. The alcohol helps break down the adhesive quicker.
1970cuda
09-12-2005, 07:10 PM
wet the windows down. wrap the inside of the window air tight with plastic and let bake in the sun. for an hour. remove tint
CarlC
09-12-2005, 08:06 PM
cuda's right. A black plastic trash bag works great.
Norwoodx55
09-12-2005, 08:59 PM
Black plastic bag trick. That was what I was looking for. I had heard something about that years ago, but couldn't remember the details.
Thanks for all the replies.
Brett
Todds69
09-13-2005, 03:39 AM
I was told by a window tinter...ammonia is what he uses. Just call one and ask what they recommend.
