    Results 1 to 4 of 4
      17x15 inch wide wheels!!!!
      Basically im having my 69 camaro mini tubbed with dse's kit as well as having the rear fenders rolled. So I'll have 6 extra inches of clearance, so im really thinking about putting 15 inch wide wheels under the car. Are there any problems I should be aware of anybody know of a tire company that makes tires big enough to fit on massive rims like these? Thanks guys.
      Anthony
      Apr 2004
      Yuba City, CA (bout 1/2 hour north of Sacramento)
      why so big?? isnt that more PRO-STREET??
      J.T.
      The new Micket Thompson SR's are 17.5 inches wide and require a 15 inch wide wheel. Boyd's will make the wheels for you, or there are a few folks that can widen 10's or 12's for you.
      67 Mustang FB/"Dragtour"
      >460 BT D1-X>MII Power R&P>4 link
      >Air Ride F&R>Wilwood 13/12>Hydroboost
      >Vintage Air>Aeromotive>Hydraulic T-O
      >Eleanor trim
      72 Mustang Mach 1 Clone Convertible/
      >429 C-6>17" Magnum's>4WDB>
      05 Mustang GT Convertible/18 Nitto's/Lightbar/
      lowered/Corsa exhaust
      06 F-150 XLT 5.4 daily driver
      My Hobby site: southernfords.net
      Jun 2002
      Long Island, NY
      Anthony,
      You're going to have to back half that '69 in order to get 17x15s back there. DSE's kit will allow for a maximum of a 345 series tire on a '69, and that's with a big frame knotch. IMHO, 345s work best on 13" wide wheels. To get anything bigger than that, you'll have to remove the stock rails and build a new set of rails a couple of inches inboard of where the stock rails sit. You'll also need custom wheel tubs. Basically when you get into this, you're doing more of a full tub and less of a mini-tub. If you're having DSE's kit installed, and rolling the fender lips, you're going to have more like 3.5-4" of extra clearance, not 6. Where are you getting 6" from? Typical mini-tub with DSE's kit is 3".
      The only problem you should be aware about, is that unless you're running a custom front sub with provisions for very large front tires, the car is going to be extremely unbalanced. As a general rule of thumb, you don't really want more than a 60 or 70mm difference in tire stagger front to rear. So, if the biggest you're going to fit up front is a 245, you may want to be looking at 315s, or even better 295s.
      I'm not trying to put down your idea or anything, just stating some facts.
