    Results 1 to 20 of 26
      help with hiding electric system under hood
      as it says in the topic, I need Ideas and prefferably pictures of the nice work you guys have done hiding your electrical systems under your hoods! I don't want wires all over the place but how can I not have that with the need of relays and stuff for horn, electric fan, blowermotor, etc.
      pictures plz
      thanks!
      Nov 2004
      NW Arkansas
      As far as the fan and other electrical items that are close to the engine or have minimal wires we run them through brake line and polish the line...again I don't reccomend this for evey wire but the ones that cannot be hidden this always looks better!
      KENNY DAVIS HOTRODS
      Jun 2001
      Orlando, FL
      No need to hide it. I like the look of well engineered wiring. Just route it in a pleasing fashion. Use mesh or plastic wrap and avoid the spaghetti look.
      jp
      ​John Parsons
      Mar 2004
      Mid-Michigan
      I use Radio Shack "Project Boxes"
      http://www.radioshack.com/search.as...=24&image1.y=36
      to hide relays and fuse holders. They are VERY inexpensive. I will usually paint the box (or boxes) to match the theme of the vehicle and run the wires in and out through the bottom or back whenever possible to keep them out of site. Really cleans things up and the aluminum covers can be polished or painted to suite the look you want.
      If you want to hide the wiring you can run it up inside the fenders. This will require rewiring a large part of the harness but the headlight and horn harnesses can usually be re-routed without to much of a tear-up...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      The Project boxes are an awsome idea.
      Mar 2003
      Boringville
      I like to use all GXL wire from Terminal supply, the stuff is really nice, I hate working with stuff like kragen wire. The nicest way to make the wires look good is to leave them bare and just use a series of small zip ties to keep them in a bundle, but be sure to make the wires straight so they don't twist up inside. If you use electrical tape in the harnesses, don't use the sticky stuff, you can get the original tape that only sticks to itself. What I do is wrap the harness in the non stick electrical tape, when I am done wrapping it I use one small piece of electrical tape to secure it at the end so it doesn't unravel(spelling?)
      You can run your main harness wires between the inner fender and fender so it is out of site, That is what I did along with the hydroboost hoses. If you think it is going to rub somewhere put a big piece of shrink tubing over the harness where you think it will rub. Also when using convoluted tubing or electrical tape, cut it short before the connection, leave bare wire(as in non covered, not bare copper!!!) about 3-4 inches before where you connect it, like a sending unit or so. And give the wire an nice curvy bend or something.
      You can make a board to mount all of your relays and such and hide it somewhere, where you can still access it.
      Here are some pics of mine, on my circuit board(or whatever you call it) it got too crammed and there are some some wires I can run in series instead and clean up the clutter, I need to go through it again, it isn't exaclty how I wanted.
      Right in the middle near the hood latch support, the wire harness was rubbing so I put a big piece of shrink tube, not sure if you can see it in the picture, the wire hold downs are from orchard and are real cheap
      You can see how i routed my wires (or how I will) behind the inner fender, the zip tie job is pretty bad, needs to be cut and redone, they are all over the place!!
      I did kind of what was mentioned earlier I used 3/8" fuel line to put my 8 guage alternator cable in and painted it black;
      Just remember, zip ties are your friend!
      and sorry for all the "look at me" pictures!!!!!
      GREAT Yody! That's what I was looking for! And I personaly love the pictures, and your car :D big fan! I might even put a cover on the circuit board and paint it black so you can't see it as easy. great ideas! thanks!
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by Camaro_Dan
      Ditto with what he said... There isnt anything on that car I dont like (ok, Id like to see it with a shaker and chin spoiler but thats splitting hairs).
      FWIW, when you put wire ties/zip ties on position them so the latch end is out of sight by installing them but not cinching(sp?) them down tight so you can rotate them around so the latch is out of sight. Once theyre positioned the way you want them then tighten them up and cut the excess off. Even though it takes longer to do all that the install turns out quite a bit more appealing to the eye IMO. Oh, once youve cut the excess off go back with a pair of flush cut wire cutters or an Xacto knife and trim the sharp edge off where you cut the excess zip tie....your skin will thank you when you have to do maintenance/repairs near the zip ties.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Front: J&S UCA/LCA, QA1 coil overs
      Rear: Caltracks/Belltech drop leaves
      Empire drive line alum drive shaft
      Polished 17x9 F/17x11 R ZR1s with 275s/315s
      Syclone
      Tow rig
      Jun 2001
      Orlando, FL
      Yody,
      Nice looking wiring. That's what I was trying to say above. Don't hide the wires, engineer them and they will look great. It requires planning to get it right, and I like that better then having then all hidden away (which sucks for maintenance).
      jp
      Last edited by parsonsj; 09-19-2005 at 06:36 AM. Reason: only two 'r's in requires
      ​John Parsons
      England
      When I ran some wires through alloy fuel line make sure the ends have a rubber gromet as the first time I had a short which set fire to the trike I built and you can not stop the short as the power travels on the alloy so you have to disconnect the battery, as the wire melted together in side the tube.
      paul67
      Mar 2003
      Boringville
      true, the power wire i have has a really thick covering, but I did notice that. Good point
      Parsons - are you by any chance related to an english man named Charles Parsons who inveted the Steam Turbine engine in 1884?
      Jun 2001
      Orlando, FL
      Dan,
      My name comes from southern England, so perhaps. My ancestors moved into the hills of western Virginia (later to be renamed West Virginia during the Civil War) sometime during the 17th century.
      If he made a fortune and provided large trust funds for his whole family, then I guess not.
      jp
      ​John Parsons
      haha, maybe he did and no one has yet to claim his fortune? :D
      Sep 2004
      Chicago - western burbs
      Another option for wire harnesses you cant hide, or are trying to dress nicly like Parsonsj said, is to "Lace" them with thread. This is old scool aircraft stuff I think, and looks pretty tidious. But details are what makes these projects.
      here's a link for an example
      Laramie, WY
      I have seen one guy do a mustang with only the dual optima batteries showing. every other wire was hidden. No lighting wires no nothing. only the nessisary engine wiring was seen. But that was super clean.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
      pictures of that mustang maybe?
      Jun 2001
      Orlando, FL
      Terry at Road Killer Kustoms does his wiring using black "sleeves" of material. I forget what the material was called, but he said he gets it at McMaster Carr. It's a nylon webbing type thingie that expands in diameter as it shortens. It's nice because it is lightweight, easy to use and gently holds the wires in place. Then you use Adel clamps or zip ties to position it and heat shrink tubing to terminate it. I keep meaning to call him and ask (again) about that.
      jp
      ​John Parsons
      Miami, Florida
      Rubes lacing idea looks tidy....
      To expand a bit on the "Lacing" mentioned above...
      http://www.infodotinc.com/neets/book4/12q.htm
      Kevin.
      69 Firebird "Eternity"
      Sep 2004
      Quote Originally Posted by parsonsj
      jp
      You mean like this
