View Full Version : minitub help
pollusky
04-16-2013, 06:58 AM
Hi, does anyone have a good thread that explains how to install the mini tubes , i dont have the dvd from "dse" thanks
Schwartz Performance
04-16-2013, 07:22 AM
https://www.pro-touring.com/showthread.php?45324-67-Camaro-DSE-mini-tub-install-pics
pollusky
01-29-2014, 12:14 AM
Hi there , my questionis simple i remove the inner tub and im ready to cut the floor and trunk pan , now do i make a line 3 inches inn, and then come back 3/4 inch out , that leaves 2 1/4 inwards right , now on the floor pan area do i have to. Cutit? Orbend itin a 90 degree so itwill bethe place to weld the spot welds to ???? And also do i weld them allaround the inaide of it ? Meaning to the trunk pan and floorpan ?? Dse instructions are very vage same as the dvd , thanks
pollusky
01-29-2014, 12:54 AM
My question is the fallowing , when installing a mini tub do i have to cut the floor pan or vend it in a 90 degree angle to spot weld the tub to it? Also after installing it , do i weld all-around the inside of the tub ? Thanks
01-29-2014, 04:42 AM
Bending it to a flange and spot welding is one way to do it- which can be easier than butt welding it depending on how good the tub would fit. We've also bent pieces of sheet metal afterwards to bridge that 90* angle.
You don't need to weld the whole tub but you can. We spot weld it several times and seam seal when complete.
-Dale
Quickboat
01-29-2014, 05:30 AM
You have to scribe the lines for cutting the floor pans b4 you remove the old tub. It works with a flange and without, but you can only bend the flange in the strait areas. Then you have a place for water to be trapped if you don't seal it well. Butt welds work great if you cut it nice. I welded solid then seam sealed. I have more pictures if you need them.
https://static1.pt-content.com/images/pt/2014/01/P1040233_zpsbb910244-1.jpg (http://s282.photobucket.com/user/quickboat/media/P1040233_zpsbb910244.jpg.html)
Finch
01-29-2014, 09:39 AM
I never bend the flange but I always fully weld the entire tub along the floor. Accurate cutting and fitment is the key.
Damn True
01-29-2014, 10:02 AM
This is, IMO the best tutorial on the process contained on PT.com: https://www.pro-touring.com/threads/46900-The-Novice-s-guide-to-mini-tubbing-a-68-69-Camaro
pollusky
01-29-2014, 10:32 AM
Thanks i will do
Damn True
01-29-2014, 10:39 AM
Please don't post the same question in multiple forums.
I've combined the threads.
Quickboat
01-29-2014, 10:46 AM
IMO the DSE templates are all but useless on the 67. I made my own.
JTs67
01-29-2014, 10:52 AM
Having done a few searches on this topic, I found the above guide to be the best one and I plan on using it when I tackle mine. The number of pictures is a big help for the more visual among us
pollusky
01-30-2014, 08:26 AM
Thanks again guys
pollusky
01-30-2014, 08:27 AM
This is what i got
pollusky
01-30-2014, 08:38 AM
I couldn't upload a picture i will do it later
pollusky
01-30-2014, 09:32 AM
Thanks , do you know if there is a diference in minitub between the 67 and 69 ?? Y have a open space in my rear right side i patch it and that did the trick but makes me wonder if i order without specifying
bikefreak600
02-01-2014, 03:49 PM
I made my own. imo it is easier than modifying stock ones. sometimes starting with a blank canvas is the way to go
dragonfly jones
02-01-2014, 04:51 PM
By far the best tutorial. I had never done this kind of work before and nine turned out perfect using this. Good luck.
02-01-2014, 11:19 PM
you have to add a filler...i just extended the frame reinforcement up to fill.
pollusky
02-02-2014, 08:13 AM
Thanks i did a small plate welded it and grind it off it looks good i still need to weld the tub nextweek when i go home maybe
