    Results 1 to 5 of 5
      Jan 2010
      Will Aluminum AC Hard Lines Sweat inside car?
      Hey guys, I'm installing a VA system in a camaro and I need the #10 and #6 to be made out of aluminum hard line inside the car. Will these lines sweat when inside the passenger compartment?
      Jun 2001
      Orlando, FL
      Sure will. You will need to wrap them in foam insulation.
      ​John Parsons
      make sure there's a drain in the HVAC box, just like the oems did...
      Southern Indiana
      Unless you use the tar wrap they will profusely sweat till the humidity is lowered.
      Use several layers or it will sweat.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Jun 2012
      Yep they drip. Forgot it on dads and it drips some of the time
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
