View Full Version : 350 olds
cutlassmann
12-08-2013, 11:38 AM
I need some advise I'm about to upgrade my transmission and I want to know what should I go with I'm looking at the 2004r are the 4l60e with electronic shifter I'm look to do the power tour next year here is my spec on my engine thanks for your feed back
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,800-6,000
Intake Duration at 050 inch Lift:230
Exhaust Duration at 050 inch Lift:236
Duration at 050 inch Lift:230 int./236 exh.
Advertised Intake Duration:274
Advertised Exhaust Duration:286
Advertised Duration:274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.523 in.
Valve Lift with Factory Rocker Arm Ratio:0.520 int./0.523 exh.
Lobe Separation (degrees):110
Grind Number:OL XE274H-10
Computer-Controlled Compatible:No
Lifters Included:Yes
Lifter Style:Hydraulic flat tappet
CCA-1441-KIT rocker arm kits
Rocker Arm Mounting Style:Stud
Rocker Arm Ratio:1.6
Rocker Arm Style:Roller tip
Stud Size:3/8 in.
Shims Included:No
Rocker Arm Material:Steel
Self-Aligning:No
Rocker Arm Body Style:Standard
Rocker Arm Nut Style:Self-locking
Slot Style:Long
Maximum Spring Diameter (in):1.500 in.
HRS-98411 valve springs
Number of Springs Per Valve:Single
Outside Diameter of Outer Spring (in):1.437 in.
Coil Bind Height (in):1.050 in.
Damper Spring Included:Yes
Spring Rate (lbs/in):246 lbs./in.
Inside Diameter of Inner Spring (in):0.960 in.
SLP-L2320F pistons
Bore (in):4.057 in.
Bore (mm):103.048mm
Piston Style:Flat top, with no valve reliefs
Piston Material:Forged aluminum
Compression Distance (in):1.612 in.
Wrist Pin Style:Press-fit
Pin Diameter (in):0.980 in.
Piston Ring Thickness:5/64 in. x 5/64 in. x 3/16 in.
HOK-3901-1HKR headers
Header Style:Full-length
Header Material:Steel
Header Finish:Silver ceramic coated
Weld-Up:No
Primary Tube Diameter (in):1 5/8 in.
Collector Attachment:3-bolt flange
Collector Diameter:2.500 in.
Tuned:No
Primary Tube Length (in):29 in.
Primary Tube Gauge:16-gauge
PT Sportwagon
12-08-2013, 02:20 PM
The 200r4 would be a bolt on. A lot of the Buick guys are doing it because of that fact. where as the 4l60 would need an adapter and the computer BS. Nice ride though.
Tim
nekkidhillbilly
12-10-2013, 02:58 PM
what he said plus a 200 is stronger if you build them and has more od. the 60e will also require a shortened driveshaft. the 200 bolts right into place of the 200.
Nothingface5384
12-10-2013, 05:46 PM
I'd go 2004 as its practically bolt in..has better gear split and stronger
Fully built should be about 1800 through Janis transmissions..think this was with non lockup converter.
If you can swing it a 4l80e would be nice and bullet proof..but more cash
