    Results 1 to 11 of 11
      Jul 2013
      Minnesota
      deadener on doors worth it?
      i have a 69 camaro and i just finished laying dynamat on the back seat area, tubs, partition, and entire floor, i have just been wondering if it is worth it to do the doors? i do not have any speakers in them and if i should do them, which areas should i cover?
      I think it makes a big difference. I did it on my 69
      Jul 2013
      Minnesota
      did you do it on the inside of the outer skin or just the outside of the inner part?
      Apr 2012
      Woodstock, IL
      Inside of the outer skin is flatter which makes the "tin" sound, it's most needed there. Dynamat type deadener is what I'm talking about.
      -Dale
      SchwartzPerformance
      Tacoma, Wa
      Same. Works really well. Gives that door shutting "thud".
      Brian
      68lovebuzz
      68 Camaro, LS6, TKO 600, Moser 12 bolt 3.73 W/Eaton LSD, hotchkis/bilstein, KORE3 C5 brakes, RUSHFORTHs and a few other tweaks ; )
      Jonesboro, Arkansas
      If the Dynamat is installed on the inside of the door (outside panel, but inside the shell) wouldn't it tend to hold moisture?
      Carl Wilson
      Feb 2011
      dallas, tx
      Sorry for the late answer I did it on the door skin.
      Jul 2013
      Minnesota
      Thanks guys looks like that's where I'll put it then
      Nov 2007
      Golden, CO
      I put Dynamat on the inside of the inner door panel since I too was concerned about moisture. It helped a lot.
      Apr 2010
      Pittsburgh, PA
      Mainly the ccd matting like dynomat is for taking away vibration resonance from speakers or perhaps downpipes.
      And you only really need 25% coverage.
      To Combat heat takes a different matting
      Same with air Bourne noises...MLV and ccf om wheelwells help with that
      Def good to get moisture out like mentioned
      72 buick skylark
      twin-turbo fuel injected buick 350..perhaps stroked to 370 in the works!
